Question about Jenn-Air JES8850 Electric Kitchen Range
Smell from jennair downdraft vent
Cleaned everything I could without sliding stove out between cabinets and getting behind it. Could the smell be coming from the blower fan behind it?
SOURCE: will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Posted on Feb 13, 2008
SOURCE: Jennair gas stove
500 dollars shoud do just fine
Posted on Apr 08, 2008
aborcass
  • 2651 Answers
SOURCE: Jenn-air downdraft blower doesn't work
thiknin thats a sealed unit, however imn sure they got it into a housing so i guess if you lloked close enough ther ewpuild be a few screws to gain access to the fan itself and with it open a quailty degreaser should work wonders in cleaning it!
Posted on Dec 08, 2008
SOURCE: outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Posted on Dec 09, 2008
cj2176
  • 520 Answers
SOURCE: Is there a vent cover for the downdraft vent. The
not that I know of but the fans on these ranges usually have multiple speeds. Try using the lowest. The fans are very strong on them. Hope this helps. good luck.
Posted on Nov 26, 2009
My downdraft vent no longer removes cooking fumes and smells for days after cooking. We have changed the screens, but still have residue coming from the vent inside the cabinet. Does this vent need to
Remove the motor together with the blower wheel, go to the local self service car-wash and use the engine de-greaser cycle (if not available, buy a can at the auto supply, spray the fan blade and let sit for a while) and get all the grease of the fan blades. make sure the fan blades are cleaned thoroughly. the fan will now ran quietly and will remove all the grease away. in the future, clean the filters often.
Jan 06, 2014 | Kitchen Ranges
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Will not cook properly with downdraft vent on. JDS9860AAP Range
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Clean vent
The vent (also known as grill assembly in GE literature) comes off after removing the two screws at the top of the unit and gently sliding the entire assembly to the left about an inch. This will allow the vent to be cleaned of grease, hair, etc., as well as giving some access to the areas behind the vent.
Dec 21, 2007 | Microwave Ovens
Jenn-Air JES8850 Electric Kitchen Range Logo
347 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
