Question about Garden
Need connection diagram of throttle and choke rods to linkage
  • cuzinken Jun 27, 2009
    Thanks for the response but unfortunatly I have a Briggs & Straton Model 19170-2161-01 8 HP. You wouldn't happen to have the manual for this?
3 Suggested Answers
  • 42 Answers
SOURCE: connecting throttle linkage on brigs & stratton snowblower
here is a site that may help you. I hope so, these things can be a real pain in the neck. let me know if you need any more help, I would be glad to help you.
http://wssemw.arinet.com/scripts/EmpartISAPI.dll?MF&app=EWSS&session=9ea7684f-6a4b-45b9-89c9-d4a5ad4e20da&cat=27&TF=epcFrame&assem=62752&highlightNode=No&selAssem=123060&mdDescrip=130232-0676-99
Posted on Mar 12, 2009
BAMOUT
  • 2478 Answers
SOURCE: ineed a diagram showing how to rod from connect throttle cable to carb on craftsman 17.5 hp model # 917-287030
In your owner's manual around page 23, it shows you how to set your
cable.
Posted on Jun 28, 2012
I need a diagram or schematic of the carb showing the throttle and choke linkages so I can set my linkage for choke and throttle
U need a service manual unless you know someone who knows what is what. Nest time you will take a picture in advance before you disassemble something.
Jul 18, 2015 | Garden
The Throttle linkage on the carburetor came off where does it go
on the inner butterfly linkage on the carburetor closest to the engine
Feb 27, 2013 | Mtd 22" Yard Machine Push Mower
Twin hs2 su carb linkage diagram
YOU dont need a diagram for twin carbys as put them on the manifold back off all throttle linkage and adjustment screws make sure thay are all down, and turn both screws down till they touch, now back off the jets nuts under the carbys and then undo them 2 turns only[thats the ones the choke move up and down] now HB on out of gear a little choke start engine adjust 2 screws 1 more turn each and choke in
make sure you have very thin oil in pistons, then when running adjust jets 1flat at a time when it runs smooth lock up the linkage and adjust screws till idle at 600 RPM.
Aug 15, 2012 | Austin-Healey SPRITE Cars & Trucks
TOOK CARB OFF TO CLEAN OUT "GUM" FROM SITTING. DURING RE-ASSEMBLT SOLID 1/16" ROD FROM GOVERNOR ARM TO THROTTLE PLATE ARM HOOKED UP OK. THEN I DISCOVERED A VERY LIGHT WEIGHT SPRING AROUND...
the little spring should go through same holes as the linkage it's purpose is to take the slack out of the rod to keep the engine running smooth a broken spring will cause it too run erratically
Jan 10, 2011 | Sunpentown 2,800 Watt 6.5HP Power...
My 1984 Ford F-150 V8 302 choke is not working?
Your choke should have a spring at the bottom under a little cover with a rod coming up and connecting to the butterfly for the choke. Usually this get a little corroded and sticks, you need to clean the pieces so that they rotate freely and the rod will move up and down. It is adjusted on some models by bending the rod to make it longer or shorter. When you push down the gas pedal for the first time in the morning it should set the choke, test this by opening the throttle while its cold out, once the throttle is opened the choke should close, once the engine is running there is a vacuum operated linkage that should pull it back some, until the engine is warm. Again if this worked before, its probably dirty so a good cleaning is in order. Hope this helps, let me know
Dec 07, 2009 | 1984 Ford F 150
The rod connecting he accelerator to the throttle came off my 1995 nissan altima i need to know what it is called to replace it
The carburetor throttle rod.Or carby linkage rod.Throttle linkage rod.Many different manufacturers have different names.Hope this helps
Sep 03, 2009 | 1995 Nissan Altima
Need help fixing a small troy-built tiller. the carb fell off and I am having trouble putting it back together. I can't get any throttle response when I squeeze throttle.
Make sure that the linkage rod or cable is connected correctly. You should be able to see the throttle plate move with the choke open.
If you need more help, post a comment.
Thanks,
Tim
Jun 28, 2009 | Garden
Garden Logo
307 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
