SOURCE: I have an old CW-C60YU
I believer to panasonic does not pull out but you have to take the unit apart by taking it out of the wall and removing a screw on top (or more) and all of the screws around the bottom edge. It has been a number of years since I worked on a panasonic but if there are screws around the bottom this is usually a sign its a cased model and not a slide out. But on the mold if you have any it will be on the inside coil only if you see no visible mold you have none. If you want to kill mold spores mix a 10% solution of bleach in a spray bottle and spray the inside coil with the unit off ketch any drips and then hold a towel ect you dont like over the front and turn on the fan (no need for cool just fan) Shut it off and repeat. Then let it set for 10 min and then spray with clean water just like the bleach but do it 3 times. This will kill any mold in your tray or backside of the coils. I hope this helps just becareful with the bleach it is very uncomfortable in the eyes only happened to me once never again. good luck
