Question about Whirlpool Refrigerators
Freezer frosts up and then the refer doesn't get cold air. I have completely defrosted it twice. Model # ED25DSXDN03
  • Whirlpool Master
  • 3,361 Answers
You have either a bad defrost heater,defrost thermostat or defrost timer.
The defrost timer is located in the control panel box in the fresh food section. The heater and thermostat are in the freezer section behind the rear panel.
On this brand it is usually the defrost timer.
Posted on Jun 26, 2009
Refrigerator is not cold coil is iced over
Posted on Aug 09, 2011
My fridge part of fridge/freezer doesn't work
Post the model number of the refrigerator. Defrost freezer behind where the cold air circulates with a hair drier. (unplug power first!) Most times when a refrigerator side stops cooling it is because the freezer evaporator behind the panel in the back of freezer (most times) has become blocked by frost=> SEE PHOTO Most times the panel before you see the frosted covering the evaporator will begin to show a layer of frost building=> SEE PHOTO (Click each photo to enlarge.) Sometimes the fresh food section of the refrigerator side will warm because ice or frost will block the damper from moving that regulates temperatures in the fresh food section. Sometimes the damper is defective and sometimes the sensor that controls the damper movement is defective. For these reasons it is important that you provide your model numbers so someone knows just what type refrigerator you have to cover all of the possibilities of what may be wrong causing the warming of the fresh food section and soon the freezer section will also begin to warm. The most likely cause are the defrost control, ADC Adaptive Defrost Control, defrost heater, defrost thermostat, air damper and air damper sensors in that order. Let me know what you have and I will try to identify just what may be happening, Thanks Sea Breeze
Dec 01, 2012 | Refrigerators
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
Coil in freezer continues to freeze up. Then we have to defrost it again. Frig doesn't stay cold then freezer food doesn't stay frozen
You will need to remove the food and shelves from your freezer and then the back panel. Look for ice buildup on the coils and around the cold air tubes that allows cold air to enter your refrigerator. If you do have frost then you should unplug your refrigerator and defrost your freezer. You can use a hair dryer to hurry the process along, but be ready with a large sponge and bucket to deal with the water. The defrost sytem is usually made of three basic components: The defrost heater, the thermostat and the timer. You can check the heater and thermostat with an ohm meter - if you have continuity - less than infinity on your meter then they are normally good. If not replace which ever one didn't have continuity. If both are good then it is the timer and you will need to order one and replace it. You can do this by going to www.searspartsdirect.com and plug in your refrigerator model number in and pull up the diagram for you refrigerator. Those three parts will be in the freezer compartment - it will also give you an idea of what they look like if you are having a problem in identifying them.
Now for the good news. Your refrigerator will work without them for a week or so now that you have defrosted your freezer! So you can plug it back in and let it get cold and just wait for your delivery. NOTE: Suggest you take a digital photo of how it looks so if you can't remember later, you have something to refer to.
Jun 26, 2011 | Maytag Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer has ice built up on the back wall. And the refridgerater will not get cold
you have a defrost problem the frost is so heavy in the freezer that the air can not get through to the refer and complete the airflow cycle, check the following
defrost board or defrost timer
bi-metal thermostat
defrost heater
my money is on the defrost board .
Aug 27, 2009 | Whirlpool Refrigerators
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Refrigerators Logo
121 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
