Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Vacuum sound is too loud
My vacuume sound is too loud than before i clean every thing but still sound to loud its work to pick up the dust but sound we can't bear it please give me the solution of this problem.
  • 48 Answers
If its aloud grating noise the motors at fault the fan in the motor is catcthing its housibng
Posted on Nov 18, 2007
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Miele upright vacuum makes loud noise and dust comes out at bottom
It sounds to me like one of the hoses is plugged, probably the one that comes from the brushroll. That would make the dust and dirt come back out the front and would not let the vac pick up like normal. Clear the plug and you're machine should start cleaning better again.
Nov 09, 2013 | Miele Vacuums
I have a craftsman 2 gal wet/dry vacuume & after using it for a wet pick up without a filter, it blows dust out while vacuuming and is extremely loud. Any suggestions. I took it apart and unclogged...
It sucked up some of the muddy water into the impeller while you was using it. Then it dried out and turned to dust. After you get done using it for wet pickup take a water hose and let a little clean water **** into the impeller, with it off the tub. That will clean it then let it run till dry. That will keep it from getting moldy also. And always put a filter on before using for dry stuff. They make a universal filter that is like a satin bag. That is what I use instead of paper one. Even for water.
Dec 17, 2010 | Craftsman 17762 Wet/Dry Vacuum
Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Jan 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Kenmore Quick Clean loud whistling noise from air exchange
Sounds like you may have a clog or restriction somewhere in the vacuum.
Oct 08, 2017 | Kenmore 34720 Upright Vacuum
Not picking up at all...burning smell..belt seems fine.
its one of 2 things, either your hose is blocked or you need a new belt,they do stretch over time. possibly the brushbar needs replacing too.
Dec 23, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Hose not picking up
Hi MightyHeidi,
About once every 9 months to a year, I have to take the hole Cleanview apart and thoroughly clean filters and get all the trash and string from the roller Brush.  I was the cleanview buckets out and rinse the filters untill i get no more mud flowing.  ThenI let it dry for a day or two. Put it all back together.  About once every 3 years, you may want to do a full disassembly to get to the Check valve at the intake of the Blower Motor.  i found mine stuck open and causing me to loose vacuum.
Sep 01, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
1,021 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
