Question about Toshiba Satellite P105-S9722 Notebook
Need Model specific touchpad drivers
I need the special driver for my touchpad on my Toshiba Satellite P105-S9722 laptop. After i installed the basic driver for the Synaptics touchpad, i couldn't use the shortcut tap zone in the upper-right corner of the touchpad to access the other 3 shortcut tap zones on the bottom of the touchpad to open applications quickly. I looked around the Toshiba website, and they didn't have the driver. A pic of my laptop and touchpad: http://www.notebookreview.com/assets/17280.jpg
  • 23 Answers
I can't locate my tourch pad icon in right corner
All you need to do is to install and update the latest driver from the manufacturer`s website and the re-install it hopefully this shall solve your problem.
Oct 04, 2013 | Toshiba Satellite P105-S9722 Notebook
When you type the psps cursor moves itself
This is a common user error (I've done it myself) this is Infact your palm on the touchpad. Along the top set of keys on your keyboard e.g f1 f2 f3 etc, there will also be symbols. One of these will reassemble a mouse. Next to the windows key and space bar there will be a Fn key. Hold these keys down together and it will disable the touchpad so you can type. If this doesn't work you likely don't have the required drivers.
Apr 17, 2013 | Toshiba Satellite P105-S9722 Notebook
Toshiba Satellite P105-S9722 white screen on stat up
Don't assume. Diagnose.
Problem could be graphics chipset, Video Cable, screen Inverter, or LCD screen.
Graphics chipset:
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
(Back of laptop - Blue)
Example of a VGA Cable, and a VGA connector, (Port on laptop),
http://en.wikipedia.org/wiki/VGA_connector
If you have a CRT type of monitor (Looks like a small TV), you can use it, or a flat LCD screen monitor with a VGA cable.
The Toshiba Satellite P105-S9722 Notebook PC, also has a DVI connector on the back of the laptop. (Next to the blue VGA port)
You can connect a flat LCD screen monitor with a DVI cable.
Example of a DVI Cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default the display should be on the external monitor.
If not;
Press, and hold down on the Fn key, (Bottom left), and tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
You will see a list. It 'hot cycles' through the list, until you come to the external monitor device you are using.
http://shop.mcccomputers.com/network-modem-cards/6037-toshiba-satellite-p100-p105-p105-s6104-p105-s9722-video-board-256mb-ts15082.html
External monitor display shows no white screen?
Your graphics chipset is good.
Go on with the diagnoses.
Problem is with the Video Cable, or in the Display Assembly.
(Screen Inverter or LCD screen)
Video Cable:
The Video Cable attaches to the motherboard under the Switch Cover, and about at the F2 and F3 keys.
It then routes under the left Hinge, and up into the Display Assembly.
From there it connects to the screen Inverter, and back of LCD screen,
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/big/toshiba-satellite-p105-11.jpg
From;
http://www.irisvista.com/tech/laptops/toshiba-satellite-p105/take-apart-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P105-P100/remove-lcd-screen-inverter-1.htm
Due to normal opening, and closing of the laptop, the Video Cable may become pinched, and pulled on.
This can lead to a simple loose connection of the Video Cable TO the motherboard, or TO the back of the LCD screen.
(The screen Inverter connection should also be checked)
Visual inspection will NOT do. You need to physically see if you can plug the motherboard connection, and LCD screen connection in.
It could be just loose enough you won't be able to see it, but will affect the display.
Sheath of Video Cable needs to be visually inspected for signs of damage. Signs of damage to the sheath, may also mean damage to the tiny wires inside the sheath of the Video Cable.
(Stretched/Broken)
Assurance that the Video Cable is not the problem, means checking out, or have checked out, with a multimeter set to OHM's, to run a continuity check of all the wires.
('Mom and Pop' computer store. See if they will check it)
Or simply replace the Video Cable. (After you fire up the laptop, and see if loose connections was, or was not the problem)
http://www.batterysupport.com/toshiba-satellite-p105-s9722-cable-p-377633.html
(Left side connects to LCD screen. Right/Top connector goes to motherboard. Right/Bottom connector goes to screen Inverter)
Video Cable checks out OK?
Go on to screen Inverter.
http://www.ebay.com/itm/TOSHIBA-Satellite-P105-S9722-laptop-lcd-Screen-Inverter-/250759700669
The plastic thin frame in front of the LCD screen, is the Display Bezel.
The screen Inverter is behind the Display Bezel, and mounted at a location towards the bottom of the LCD screen frame.
A screen Inverter is tested with a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
It is for this reason that those who do not have access to a sensitive multimeter, usually just replace the screen Inverter.
(Also low cost, and ease of access to replace)
Screen Inverter checks out OK?
Problem is the LCD screen,
http://www.amazon.com/SATELLITE-P105-S6084-P105-S9722-P200-140-REPLACEMENT/dp/B007QEEYGE
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Bet it's the video cable, or screen Inverter, that is the problem ]
[ Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Toshiba Satellite P105-S9722 Notebook PC, uses One CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
General example,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
A CCFL contains -> Mercury, just like Fluorescent lighting used in homes, and businesses.
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
90 Percent of the Time the fault is a bad screen Inverter.
Primer over.
Oct 16, 2012 | Toshiba Satellite P105-S9722 Notebook
Touchpad not in device manager
Hi There,
The touchpad will normally show up under input devices in device manager. If you don't see it listed, check to see if your touchpad has a manual on/off switch located on the laptop keyboard (sometimes under specialized function keys)
If a switch doesn't seem to be the issue, try reinstalling the drivers for the touchpad, which should be available on the toshiba website.
Aug 06, 2012 | Toshiba Satellite P105-S6197 Laptop
I've installed Windows 7 on my Toshiba Satellite P105-S9722 Laptop - and I keep getting white screen. I updated the BIOS to 4.8 and installed 4 gb of memory. I've tried different video drivers but keep...
This laptop came with either XP or Vista on it and if you wish to use Win7 32 or 64bit you must install all of the drivers and preferably make a fresh install. There is only one video driver that will work!
To gain access to the correct drivers, go to Toshiba.com and log your laptop in. The web site will advise you on which drivers you require.
I feel sure that that is the only problem you have that is giving you this headache.
Don't forget unless you load 64bit Win7 you may not be able to utilize more that 2048 Mb of memory.
Dec 22, 2010 | Toshiba Satellite P105-S9722 Notebook
My Toshiba will not read a cd/dvd. I can't seem
rollback driver-or disconnect dvd/ram and reconnect
Mar 10, 2010 | Toshiba Satellite P105-S9722 Notebook
I AM TRYING TO BURN A DVD USING TOSHIBA DISC CREATOR, BUT THE COMPUTER KEEP SAYING THAT THERE IS AN ERROR CODE : 0600277-26-28031100. HOW CAN I FIXED THAT?
try to re-install the toshiba disc creator driver and try to burn the cd again. if it doesn't work i suspected your dvd rom drive is faulty. you need to replace it. call toshiba and request to replace the drive.
if machine is under warranty no need to pay for replacement.
Jun 30, 2009 | Toshiba Satellite P105-S9722 Notebook
Need Model specific touchpad drivers *EDIT*
Hey there, not sure if you tried this or not but this is the hardware setup for your laptop
seth
http://cdgenp01.csd.toshiba.com/content/support/downloads/util_hw_setup_25547A.exe
Jun 27, 2009 | Toshiba Satellite P105-S9722 Notebook
I canot play a sound on my laptop
I had this same problem when I put a new operating system on my friends toshiba. It ended up being the drivers needed to be reinstalled.
to check this:
  1. right click on my computer
  2. click on properties
  3. click hardware
  4. click device manager
  5. look at list and see if anything is highlighted
  6. Right click on yellow ? and scroll down to update
  7. reboot after installation
Oct 25, 2008 | Toshiba Satellite P105-S9722 Notebook
Toshiba Satellite P105-S9722 Notebook Logo
194 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
