Question about Sitecom (WL -004) Wireless Adapter
Can't setup to virgin braodband
Sitecom 300n router wl-341 .
can't setup to virgin braodband
gives me a 7 number key and when I type it in, it goes on about ascii and dexa... ?? saying the key should be in that form and different lengths
I have no idea what they are on about
  • 51 Answers
You mean ascii and hexadecimal.
  • Hard wire your router to your PC with an ethernet cable
  • Open your web browser, go to website http://192.168.0.1
  • Input username/password both are "admin" (without the quotes)
  • choose "wireless settings" (third tab from left)
  • go to "security" (fourth tab from left)
  • Choose WEP (if the first box on this page already says WEP you may skip this step)
  • choose 64-bit
  • type random 10 digit code into key 1 (eg. 38-38-2D-E3-B0)
  • Save settings (bottom of page)
  • write code down somewhere or make it easy to remember
  • disconnect your ethernet cable from router, try to connect to wireless network, enter code (from above) and it will connect.
Posted on Jul 01, 2009
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
I cant configure my MikroTic Wireless router with Sky Broadband?
Look for SSID. It is your username and the key is password. You may have to choose between ASCII and Hexadecimal.
ASCII is words or phrases. Hex is numbers and letters (random).
Nov 20, 2012 | Computers & Internet
My Sitecom 300N repeater resularly loses its connection to my BT homehub. I think this is when the H homehub goes down sometimes. Resetting the Sitecom from scratch is a pain but resolves the problem. 3...
I also had this problem when the BTHomeHub goes down, power loss etc. I seem to have fixed the problem by changing the wireless config in the homehub to use a fixed channel, (the default is automatic which means it changes each time it restarts). This has been running trouble free for a couple of weeks through a number of power outages.
Can't help with Qs 2&3, get the same problems but less of an issue now that the thing works all the time.
May 16, 2010 | Computers & Internet
I can connect a sitecom 300n(wl-330)but cannot get an internet connection the router is an Orange livebox
you need to put in the connection tab
the name of the router you are trying to get in to
and the security key (if enabled).
Try disabling the security key on the router to test this out.
You may also have MAC filtering on,
in which case you must disable it or
put in the MAC number written on the sitecom label  into the router.
Mar 07, 2010 | Computers & Internet
I selected an MAC adress in the software of my WL312Sitecom router.I guess the wrong one because now I can't access 192.168.0.1
Reset the router via the little hole in back/underneath. Then simply set it up again, properly. Below is a link for the manual it has a step by step walk through for setup to help you. www.sitecom.com/showdownload.php?id=3779
Mar 05, 2010 | Sitecom (WL -004) Wireless Adapter
I WANT TO SETUP MY ROUTER TO WIRLESS
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Go to START and find RUN, then type in CMD and hit ENTER, should throw up a black box (Dos window) you will type IPCONFIG and it should give you an adapter gateway ip address like 192.168.0.1 or something like that, from there close out that box and launch internet explorer or firefox or netscape or whatever browser you use. Type in the ip address where you would normally type www.google.com. Hit ENTER, this will interface you with the router. It might be password protected. Usually the username and password are both the word admin. If not look at the bottom of router for password. Look for wireless tab once in router and select network type as wep. Look for the key that the router automatically generates. This will be your wep key. Now your wireless connection will be secure. Hope this helps...Tennis123
May 15, 2009 | Sitecom (WL -004) Wireless Adapter
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
Sitecom (WL -004) Wireless Adapter Logo
203 people viewed this question
Top Sitecom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Sitecom Computer and Internet Expert? Answer questions, earn points and help others
