Question about Viper RCVGC022 Remote Control
FCC ID: EZSDE17152- Viper Remote Starter
I have a band new Viper Remote Starter,  the newest one that came out in the market, and I've been having it for over 6 months and at the beginning it was working wonderfully. But now the remote is giving me some problems. The Remote Starter will start, but not like it did when I first bought it. On the area where it says " VIPER" there's an orange light that comes out, and next to the " f " button a red light comes out at the same time and they both make a beeping sound after the car is turned on, and the sound does not stop beeping even when the key is in the ignition. Sometimes I have to take the battery out and put it back in thinking that that's the problem with the remote, but i guess there's something more to it than taking the battery out... This is a frustrating problem that I can't seem to figure out the solution for it. Please help me with this problem, I don't know what else to do with this remote, sometime i want to smash it on the ground but I know that won't work or help. LOL!,  Thanks for taking this matter into consideration. Zaida, From Texas
4 Suggested Answers
SOURCE: viper auto alarm stuck in valet mode
Doctor C,
I to have suffered the trial and tribulations of the viper car alarm experience and am happy to pass on my knowledge.  I found this answer online after googling "viper valet mode"
"The LED is solid now, correct? This means the unit is in Valet mode. To get out of it, turn the key to the "on" position then back off, and just press your black program button hidden under the dash.  The installer should have shown you where they installed the black program button."
Good luck
Scott
Good Luck
Posted on Oct 19, 2007
Agent Dort
  • 216 Answers
SOURCE: Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Posted on Jul 07, 2008
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Horn does not sound when locked by viper 5301
??? Have u tryed a new battary. ???? is there a way to re program it ck online or call the DLR..
Feb 05, 2012 | 5101 LE 1 Way Car Remote Starter System
Buying a car and the guy pulled out the viper alarm and now there s now fuel pressure what can that be from?
One has nothing to do with the other. The security system only interfaces with the starter wire. Just make sure the starter wire is reconnected and other than that its mechanical.
Oct 15, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I have a 94 grand prix with a dei remote start not sure what brand remote says your valet and the fcc id is ezsdei471 and it has 2 grey buttons on it anyway the remote unlocks the doors and the dummy...
It sounds like there's no power going to the starter wire. Try and locate the brain under the dash for the remote start. It should be black and about twice the size of a deck of cards with a few harnesses hanging out of it. Usually it is zip-tied to a wire harness or bracket to keep it secure and from falling down onto your feet. There should be several wires much larger than the others, and you should see fuseholders on the 2 red ones. Usually one of the fuses is used solely for the starter. Check both fuses on these larger wires. Should be 30 amp green ones if I remember right. Also, while you have the brain accessible, write down the model number on the brain itself to help you in the future. Most DEI remotes can be used for almost any DEI/Viper/Your Valet system, so it's really hard to tell what you have just by looking at the remote. If the fuses are fine, you may need to take it to a shop (anyone that sells Viper and such). If you have a chip in your ignition key, it may also be the security bypass module that gets installed with the remote start. You will only have this bypass module if you have the little chip in your ignition key. Hope this helps, good luck.
Chad
Nov 24, 2010 | Viper RCVGC022 Remote Control
No install instructions
email me at face2face11@bellsouth.net and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
Dec 31, 2008 | 791XV The 791XV is a 2-way Security and...
Viper RCVGC022 Remote Control Logo
342 people viewed this question
Top Viper Televison & Video Experts
Hjalmer Lamminen
Hjalmer Lamminen
Paul Bade
richie46
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
