Question about Gateway Computers & Internet
Fn key problem with Gateway notebook
My Gateway notebook thinks that the Fn key is pressed when it is not, and it thinks the Fn key is not pressed when it is. Take the “k” key ,for example. This key also has a blue colored “2” on it, meaning I am supposed to get a “2” if I hold down the Fn key. Just the opposite occurs. If I do not hold down the Fn key, I get a “2”. If I do hold down the Fn key, I get a “k”. The fact that pressing or not pressing the Fn key changes the behavior of the “k” key, makes me think the Fn key is not stuck. It also does not look or feel stuck.
  • 334 Answers
Hey there, this is an easy fix, just press the num lock key:) let me know if for some reason that doesn't work
seth
Posted on Jun 26, 2009
  • dave schwefel Oct 13, 2011
    thanks dude, I was stumped. Dave - with a durabook, Oct 12th. Thanks.
  • darkova123
    darkova123 Feb 16, 2014
    when i activate numlock i get numbers when i disactivate it,i get nothing, i only get the letters whhen i hold fn key to, plz help
Searching for how to turn of hot key on gateway sa1?
hold the FN key and press NumLK key... you currently have the numlock key on... turn it off and your problem goes away
Oct 18, 2012 | Gateway MT6840 Notebook
How brighten the screen?
Look on your keyboard on the "f" keys (f1, f2, etc...) for a symbol that looks like a sun or shining light. Something that would indicate brightness. Now, hold down the 'fn' (function) key on the bottom left of your keyboard and then press the backlight key you just found.
Mar 01, 2011 | Gateway MX6214 Notebook
How do I get my keyboard lights to turn on for a new gateway laptop?
Press and hold the FN key on your keyboard, While holding FN, press the F1 key one time. Then let go of FN.
FN-F1 on your system toggles the system status lights on and off.
Dec 25, 2009 | Gateway 7330GZ Notebook
Connecting Gateway 450 notebook to tv using vga to svideo convert
It is possible that the signal from the portable is not compatible with your convertor or device, however, if you are getting no image at all (not even lines etc.) then the laptop may not be set to send a signal through the VGA port at all.
To toggle the image to the VGA port do the following
  • Press and hold the FN key on your keyboard
  • While holding the FN key, press the F3 key one time
  • Let go of the FN key
  • Wait a few seconds to see if you get anything thing on your external device.
  • If you do not then press FN-F3 a couple more time waiting a few second in between each try.
the Fn-F3 toggle switched between the LCD only, LCD+CRT, and CRT only modes. You may find that it works on the CRT only mode but does not work correctlly with both. When this occurs it's a limitation between the compatibility of the settings requires for both screens, so you would only be able to use each by themselves not together.
Nov 19, 2009 | Gateway 450ROG Notebook
Need to unlock Fn Key on Gateway laptop
Press the FN key and F11 same time... If that didnt work, Try Fn Key and The Pause/Break Keys same time
Nov 16, 2009 | Gateway MT6728 Notebook
I have gateway model MT3418 What key with FN do I press to lighten or darken screen?
To change the lcd brightness, press Fn key and the up and down arrow key's at the lower right of the keyboard.
Apr 15, 2009 | Gateway MX6453 Notebook
10 key numbers on laptop will not shut off unless i hold th fn
Have you tried pressing Number Lock? The key may be labeled "Num Lock". If the Number Lock key is labeled with a different color than the letter keys, you may have to hold the corresponding colored key (like Fn or something) while pressing the Num Lock key.
Feb 01, 2009 | Gateway MX8711 Notebook
Screen
1. Check Power ( this includes the power supply )
2. Check Battery
3. Check to see that the DC power jack is not loose or broken.
4. Most notebook/laptops have a function key FN when the FN key is pressed you will be able to press the F keys , one of them will have a little monitor drawing on it.
if you press them both FN+F-Key ..... which could be F5 in this case , it will cause the computer to switch to either the VGA output , or the notebook/laptops screen. sometimes they get pressed by mistake and the person thinks they have a broken machine when in reality they do not.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division IEEE
Sep 24, 2008 | Gateway ML6732 Notebook
Function keys
Hi you need to hold down the function key (FN) and press the number lock key (num lk). hope this helps
Jan 14, 2008 | Gateway MX6453 Notebook
Computers & Internet Logo
1,374 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
