Machine was working well then all of a sudden started tearing tube at end ! Bad tubes? Using same brand forever.
My premier papers do that, the zizzag and gambler do not, I think some papers are thinner and cheaper than others.
All machines are using cigarette tubes and work in a similar way. If just look at your cigarette tube carefully, checked that if there is any gap or empty space in filter tube or it is loosely packed, be sure that you have put enough tobacco in your chamber. Follow the above instruction may the cigarette tube will not tear from at end.
This is some what normal.
So, how do you replace the little rubber grabber? It is tearing my cigarettes up, pushing them out when only half full, etc. I put a piece of paper between the rubber and my cigarette and it rolled some very well, but then started loading half way and done again.
They will do that after time because of the tobacco residue buildup on the little rubber holder for the tubes. Take a cotton swab with some cleaner or alcohol and wipe it a few times till it's clean. Then go ahead and try it again, see if it still does it. If it works, great. If not? It could be the injector pushing too hard or too long. I have gone through a few of these (worn them out), and it is possible that the inner moving parts are wearing out, creating slop that will cause this also.
I just found out that if ur rolling 100mm tubes put the part bk on for rolling shorts then try it that's fixed it for me hopefully will help some of you as well!
BABYGURL69
