Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
Electric coils do not work
Self cleaning oven about 3-4yrs
old. electric controls come on but
the electric coils donot come on inside.
I have changed the top fuses
    President:
  • 1,723 Answers
Check the connections on the back of the oven feeding the elements. If good, follow back to control switch and check everything there.
Posted on Jun 26, 2009
After I replaced the lower coil in my Frigidaire oven, the self cleaning part does not work.
Hi Carol Eggers, thank you for your inquiry!
I understand that your wall oven is not allowing you to perform self-clean after you replaced your bake element. It sounds like it could be an issue within the control panel or sensor inside of your oven. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 22, 2014 | Frigidaire FPMC2785KF Professional 27...
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
After putting ovens through cleaning mode, ovens are not working, no heat, ovens less than a year old, caldwellb84@yahoo.com. unit is electric not gas.
Check out this tip... You probably burnt something up besides the bad stuff in the oven....like the wiring...or a control...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Oct 18, 2010 | Electrolux 30" Self-Cleaning Freestanding...
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Self cleaning
Sometimes, according to what I've seen.  My theory is that the elements are probably covered in grime and this causes the damage.  As far as the control...I don't think that makes sense.
Never use cleaner on the elements..also causes damage.
A typical duty cycle for cleaning is 2- 2.5 hours.  Longer and you could burn them up, too.
Nov 28, 2008 | KitchenAid KEBC101 Electric Single Oven
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Self Clean cycle
Is this range electric? if so then does it bake or broil ok? if the answer to both the questions is yes!.. I don't think you need a new range, Cleaning cycle is based on both elements working along with other componets , if you are an handy man there is a mini manual on the range somewhere it could be inside the back panel, that will give you some info, if you are able to read the wiring diagrams ect, or could be your digital control, if you donot feel good about this and most don't I would call a good service Tech...
Guest 2
Jul 12, 2008 | Hotpoint RB757 Electric Kitchen Range
Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Aug 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
98 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
