Sony Dual-Alarm AM/FM Clock Radio with Automatic Time Set Logo
A
Anonymous Posted on Jun 16, 2014
How do i cancel the alearm
Sonny model ICF-0430
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
2helpful
Code 0430 cleared as soon as I had catalyc converter replaced, now 2197 comes up
Year make model engine size all critical to be able to help you.
I have a ICF-SW1 which I believe is the predecessor to SW77. Can you help with this model?
Need a more descriptive question please. I know this model and the usual problem lies with faulty capacitors. Contact me .... poikaa(at)yahoo(dot)com
I DONT HAVE USER MANUAL OF SONY RADIO ICF-SW30 , I DONT KNOW HOW TO USE IT
http://esupport.sony.com/US/perl/model-find.pl?mdl=ICF-SW30
Sony ICF 2010 Shortwave scan does not scan, it beeps.
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Sony ICF2010 Scan does not work.
The SONY does not scan non programmed memory channels, you must have some programmed in.
2answers
Clock radio
Search for the manual in amazon.com. It is there. I just printed it.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
