Question about PfaFF Sewing Machines
I have a Pfaff 2025, serial # 304 971 696 I get thread tangles
I have a Pfaff 2025 Classic Style, serial # 304 971 696 I get frequent thread tangles. I read that there was a recall on the hook in the bobbin area. Is my machine in that recall? In spite of having it to the dealer several times, he has not replaced it.
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 9 Answers
SOURCE: burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Posted on Jul 17, 2009
  • 55 Answers
SOURCE: SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
Posted on Jul 28, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
SOURCE: top thread gets tangled in bobbin and won't pull up like
I'm new to sewing, and I had a similar problem where the top thread went all the way around the bobbin thingy and got stuck every time--solution: the bobbin case wasn't all the way in.  The arm had to go in a slot at the top and it sort of snapped in, then it worked fine.  Maybe it will help you!
Posted on Nov 06, 2009
Pfaff 1467 needle jammed in fabric and hand wheel stuck
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
May 01, 2017 | PfaFF Sewing Machines
Pfaff 1196, needle won't pick up bobbin thread. Can I fix that?
First, be sure you install a brand new needle. Old, damaged needles frequently will not pick up the bobbin thread. If not that, then the machine is out of time. Search the internet for sites and videos discussing sewing machine timing or take it for service.
Dec 18, 2016 | PfaFF Sewing Machines
How to thread a pfaff 2042 machine
You might try contacting Pfaff Support:
Machine Support
May not be your model, but frequently machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading.
Threading Pfaff Sewing Machine Select mov
Manual:
Pfaff quilt style 2042 manual
FAQ Knowledge Base
Dec 17, 2016 | PfaFF Sewing Machines
While sewing a straight stitch my Pfaff machine classic style 2025 it starts to zig zag. What`s the problem?
You have unknowlingly changed a setting and are using a decorative stitch of one kind or another.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Jan 14, 2015 | PfaFF Sewing Machines
My Pfaff Classic Style Quilt 2027 is getting large thread snarls on the underside of the fabric.
Top tension problems. Tighten the tension.. and make sure you hold the threads when starting a seam.
Sep 02, 2012 | PfaFF Sewing Machines
The bobbin is loaded but when i go to use it I get a tangled mess of thread underneath my fabric
Usual cause is bobbin threaded wrong or more commonly improper tension of the upper thread. Sometimes the bobbin tension may be wrong due to thread size change etc.
Sep 04, 2009 | PfaFF Sewing Machines
Teach me how to thread my new machine
1. Do you have the sewing machine manual?
Mar 23, 2009 | PfaFF Quilt & Craft Pro 7530
Sewing Machines Logo
353 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
