Question about Maytag MAH6700AWW Neptune Front-Load Washer
D5 error Tub will not spin - Door will not open - Repeated attempts only making a humming noise.
    Sergeant:
  • 222 Answers
Sounds like a bad door lock replace the door lock assy.
Posted on Jul 14, 2009
Will not start
Posted on Jul 05, 2009
Water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 07, 2012 | Washing Machines
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
Sep 12, 2017 | Equator EZ 3600 CEE Front Load Washer /...
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Won't spin
We had the same problem. It was the door lock. In addition to the regular lock that prohibits you from opening the door while the machine is running, There is a "wax motor" lock. If this lock fails, it won't do the final spin. Think back to your top load washer, it wouldn't spin if you opened the top. The motor is a universal motor that is used on many front load washers. We found the answer by googling "front loader won't spin" - the wax motor costs $12. The wax motor is inside the door switch control. It opens up with a screw driver, be very gentle.
Oct 11, 2009 | General Electric WSSH300G Front Load...
Dryer is making a humming noise and wont spin.
you probably have broken belt which drive the tub or drive wheel. open the top and see if a belt or open the bottom you see it there
Jun 23, 2009 | Amana DLE330RAW Electric Dryer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Dryer not spinning
it makes a humming noise..defective motor,,also you need to replace door switch...onthejob
Jan 10, 2009 | Kenmore 72802 Gas Dryer
MAYTAG NEPTUNE
Not sure if you solved this one yet..but ...
d5 - Door is open during washing
I have some more codes for a Model # MAH6700AW if you need them.
Nov 04, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
262 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
