Question about HP OfficeJet J4580 All-In-One Laser Printer
Small plastic paper got eaten by printer by printer
What is safest way to get plastic paper out, without damaging printer
  • 27 Answers
Pull it gently from the back
Posted on Jun 29, 2009
I need to know it okay to eat a ham that been in the freeze for a year I got from a job I never open it up I just put in the freeze how long before it not any good to eat
If it has been frozen the entire time it should be safe to eat. Most anything that has been continually frozen should be safe to eat if cooked and eaten soon after thawing it out. Bacteria is what spoils anything and bacteria cannot multiply in a frozen environment. Depending on what it is,how long it was frozen and whether or not it was exposed to air while being frozen will determine whether or not there is an undesirable change to the taste, color or texture.
The best (safest) way to thaw anything out would be slowly in a properly working and set refrigerator.
Your ham should be OK,especially if it was frozen in its original plastic packaging without being opened or exposed to air before freezing. I have eaten previously frozen hams and turkeys (in their original packaging) that were in my freezer a lot longer than one year... and I never noticed any difference in taste.
Nov 14, 2015 | Home
How do I aline the paper sensor Someone jerked paper ouy causing the sensor to move?
Hi Paul
without knowing the make of printer its a bit of and open ended problem normaly the paper entry sensor will be found Above the paper tray towards the rear ................this can easily be blocked by a small piece of old paper(paper jam) mucking up the printer .....normally its fixed with clips hole and plastic wedge type arangment
Dec 22, 2014 | Office Equipment & Supplies
How do i adjust heat settings in xerox 6110
If you tried to print on a transparency sheet for ink jet printers, in your laser printer, you could have damaged the heating rolls. The plastic could be molten on the roll and you won't be able to remove it without damaging the roll. As long as there is just a spec of plastic on the roll you will have paper jams. There should be transparency sheets for laser printers to, but always make sure you have those before using in a laser printer.
Jun 21, 2014 | Xerox Phaser 6110 Laser Printer
Paper jam 1
The problem may lie in the fuser or imaging drum; there may still be small pieces of paper jammed in them or any where else along the paper feed roller/trail. If you do remove the fuser or any of the other consumables, make sure the printer is turned off and the power cord removed at the outlet (receptacle). Allow the fuser enough time to cool down. Serious burns (1st, 2nd, and 3rd degree burns) can occur- the fuser gets extremely hot.
Should you need to remove the imaging drum to inspect it for any more tiny pieces of torn paper, do it in a very dimly lit room; use a black plastic garbage bag to store it in. If the imaging drum is exposed to direct light, especially sunlight- you will damage it completely, or possibly shorten the life of it; very expensive to replace.
If there is serious damage other than what I covered and it is going to cost more than half or 2/3rds of what the printer is worth, you're best option is to buy a new one; and dismantle the damaged printer for its precious metals- you can get some money back at the scrap metal yard for the gold, copper, steel, and aluminum; and recycle the plastic parts for $$ too, if available in your area.
Nov 21, 2013 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Well i would like to know how i can erase printer ink for paper minus damaging the paper thanks in advance
You can try hidrogen peroxide,isoprolic alcool or other bleaching agent. But do not rub.
PS: Inkjet ink can be even washed from paper with water.
First at all experiment what method is the safest for your document.
PS2:Toner from laser printers cant be erased.
May 11, 2011 | Computers & Internet
My printer keep saying out of paper bu it's not
If you have had a paper jam and extracted paper from it, the paper sensor may have been damaged. Often these are an optical pickup that has a small lever that is moved by paper when the printer picks up a sheet.
Open the printer and look for this lever (usually plastic) and see if there is paper residue holding it from moving OR residue blocking the optical pickup.
Aug 30, 2010 | HP PSC 1210 All-In-One InkJet Printer
Canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Jan 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Paper jam, removed paper but still says jammed. Is there any way to tell where the jam is or reset machine ?
You should be able to have a piece of paper feed all the way without hanging.
Most of the times, you can see a small piece of paper stuck in a corner.
I have used a cut piece of plastic ( from a file folder ) and worked small pieces out that way.
Good luck, Happy Holiday's
Nov 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
MP 530 keeps telling me that there is no paper in the trays.
on the paper tray, there is a small plastic sensor that tells the printer that the there is paper on the tray, this may be damaged or stuck one way. please have this checked by consulting the site FAQ on cleaning the Pixma MP
Sep 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Hp color laserjet 1600
Sounds like a bad TRANSFER Belt
Dec 29, 2008 | HP Color LaserJet 2600n Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
