Question about Avanquest MyDeluxeInvoices & Estimates for PC
My file won't open and the backup isn't working
Program crashes when I try to open my *.inv or *.bak file
I have had similar problems with an older version of MyInvoices, yet I first get a message saying, "Customer file is corrupted." I actually was surfing to see if anyone has had similar problems with the customer file. I have had to go to the extent of restoring things on another computer and then putting it back on my original computer. I have even, at times over the years, had to delete all of the files from the one computer in order to restore it from the other.
However, there is sometimes an easy fix to your problem: the program intermittently creates "Safe" versions of your file. These versions can be found in the "Safe" folder (which is located in the MyInvoices folder of the MySoftware folder under Program files). There are numerous "Safe" folder which are likely numbered. You can check the date and time that they were automatically created and select the most recent one. However, restoring it this way will cause you to lose any information that you inputted after this date/time. Hopefully you will have a very recent one and will be able to access your data. Hope this helps!
Posted on Jun 27, 2009
I lost two large files that somehow got corrupted, I had to get the Supervisor over our IT department to try and solve....after 2 hours we were out of ideas, he googled and we found the very problem we had encountered and thanks to RookieJ My IT guy went step by step and got the two files back!! Hats off to you RookieJ I was facing two days of re-inputting the invoices in these two files!!! You are my hero!
Thanks, Hummelcat
Posted on Oct 28, 2009
Our laptop got stolen who had the lotus 123 and 4 installed on it.
BAK is a backup file. WK4 is a wordperfect file.
Open Office should open them.
Lotus 123 is available as a download.
http://en.softonic.com/s/lotus-1-2-3-download
Feb 26, 2016 | Computers & Internet
I used a Toshiba 1/2 TB external drive with NTI Backup Now EZ software for some years and then the laptop crashed. After byuing a new one the happy moment when all could be restored never appeared. The...
Maybe the restore function only works with the original piece of equipment. Ouch.
You might want to contact the manufacturer of the software to see if they have a fix or solution. Good luck!
Apr 10, 2017 | NTI Backup Now EZ
HoursTracker Lite crashes shortly after opening
Same here. I reinstalled once and restored from backup, but now it's the same again.
Apr 18, 2011 | Carlos Ribas HoursTracker Lite - Timesheet
I need a back up from windows XP Home Edition
How To Buckup Winxp Unknown to many users, Windows XP offers a simple and easy to use program made specifically to backup your system files. The program can be found by clicking the "Start" button, and navigating through the following menu items; Programs, Accessories, and System Tools.
The program is entitled backup, however do not let the lame title fool you, as the software is both simple to use and very powerful. It is very simple to use, because you only have to specify where you would like the backup file to be stored; there are no challenging questions asked. It is very powerful because it enables you to create a single file that is a complete backup of your entire system.
Once you open the program, you will be greeted with a window containing the backup & restore wizard. After reading the window, you may click on the next button, and you will be greeted with two options; Backup files & settings and Restore files & settings.
After you select "backup files & settings" and click the OK button, you will be greeted with a list of items that you can backup. Because the purpose of this article is to explain to you how to backup your system files, select the option "All information on this computer" and click the next button.
How to successfully make a backup copy of your entire system.You will then be asked for a location to store the *.bak file. Since Windows XP is extremely large, storing the *.bak file on floppy disks is not feasible, as it would take several hundreds, if not thousands of floppy disks to hold the file.
Instead store the file locally on your hard drive. Once the file has been created, you will be prompted to insert a floppy disk. The software will then write a program to the disk that allow you to boot the system using the disk, and restore your system via the *.bak file.
Please remember that the backup file can be extremely large, and requires you to either place it onto a CD, DVD, or in a well protected folder or partition on your computer system.
How to easily restore your backup files.If you ever have the need to utilize the backup file, simply place the floppy disk in your drive, and turn on the computer. The system will boot from the floppy, and ask for the location of the *.bak file. Once you provide the system with the location of the backup file, your system will begin to replace your corrupt system files with your backup files.
Feb 02, 2011 | Microsoft Windows XP Home Edition
Corrupt MYOB data file
Our MYOB 14 .dat file is crashing. We suspect a corrupt entry in the database. The file will open but as soon as we trying to do anything the program closes and produces the following error: MYOB must terminate. Termination Code 1284 Important Details: Error -3000 in DMGTEKey (5037:7000:69) Seems to be the same error every time. We have tried running MYOB's Verify and Optimise tools with no luck. Each time either tool is run the program crashes and displays the error: An error occurred while attempting to compact the database. DM Error = (-3000-5049-7000-158) Restoring from a backup is not an option as last backup was 3 months ago. So looking for solutions to fix the current file please. Will not be satisfied if the solution is to take it to MYOB. Need someone who can actually dig around inside the file and correct the errors??
Apr 25, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
Wordperfect crashed in the middle of working on a document
Find the WP directory and locate the backup file. Copy it to somewhere else.
The directory will be something like WordPerfect\12\Backup with various other directories on the front of that such as c:\program files\ etc.
Open the copy and see how much of the original is present.
Michael
Reinstall WP
Open
Mar 17, 2009 | Corel WordPerfect Office 12 Standard...
I had a cad drawing and I was messing around with it and lost it tried recover and can't recover it. I had someone resend it to me and every time I get it it changes to a file I can't open it is white page...
Most CAD programs such as AutoCad have a history of recently opened files. In AutoCad go to TOOLS/ OPTIONS/ FILES/ Automatic Save location. There you should find a file with the same name but a different file extension such as .BAK (AutoCad back-up) You can set AutoCad to automatically save to any time period, such as every 15 minutes.
Make a copy of this .BAK file so you keep that unchanged, Then change the file extension of the copied .BAK file to .DWG. Then you should be able to open this file. A file with an extension containing the $ symbol needs to be recovered using the programs recovery tool, in FILE/ DRAWING UTILITES/ RECOVER
If you're using a different CAD program look for this backup file wherever the programs Autosave files are set to be stored.
One other possiblity is the file extesnsion is set by your computer to open with another program for some reason. Right click and hit "open with"
Let me know if this helps
Jan 07, 2009 | Computers & Internet
"My Invoices & Estmates Deluxe" - Repair corrupt '.inv' invoice file
When the program prompts, then creates a backup file for a database, it has a .bak suffix (not amazing). However it also creates a folder in the 'Safe' folder under c:\program files\estimates... All I had to do was locate the most recent version of the db files in the Safe, copy the folder to the c:\documents and settings\...\Invoices directory, and the most recent uncorrupted database was readily available for File Open. Voila.
May 30, 2008 | Avanquest My Invoices And Estimates Deluxe...
Is it possible to restore from shadow copies of a crashed harddisk?
My harddisk crashed with lot of important files on it. I sent it to a trusted recovery service.
how can possible restore delete any file & folder on my pc harddisk
May 23, 2008 | Seagate Momentus 4200.2 100 GB Hard Drive
Avanquest MyDeluxeInvoices & Estimates for PC Logo
828 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
