SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
chk the switch of ckt bord or chak the pannel of ur dishwasher
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
SOURCE: kitchenaid normal cycle light and cancel light
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
SOURCE: Kitchenaid dishwasher KUDPO2FRSS normal and cancel
Where is the filter on the Kithchenaid KUDPO2FR$$4 Dishwasher ?
