Question about QuarkXPress
Placing a jpg file error 69 pops and i can't see image.
  • 126 Answers
Try opening the file in Photoshop, copy the image to a new document and save. It might solve your problem. ps There are lots of different .jpg standards, other files like .tif are more stable.
Posted on Jul 14, 2009
Convert NEF format to JPEG
You can use the Nikon View program that should have been included with the camera. or you download the current versions of Nikon ViewNX or Nikon Capture available free at Nikon Imaging Products Software
Dec 11, 2016 | Nikon D Cameras
Tip
How to hide files in a jpg photo
1) Take two files -
one which you want to hide and another will be the jpg image(of any size and dimension)to hide that file
If you want to hide multiple files in one jpeg image, just zip them into one file
2) To make the process easy, Copy the above two files to the C:
3) Now open the command prompt (Go to start, Click "RUN" and type "cmd").
4) get to the root by typing cd\ or you can give the path name where the files are located
5) Now type the following command:
copy /b imagename.jpg + filetohide.ext new_image.jpg
6) Now a new file new_image.jpg will be created
7) Double click on the file and it will open the image which you used to hide the secret file
8) To access the hidden file simply change the extension from jpg to orignal extension of the hidden file,
Example: I took an image filename "myphoto.jpg"
I wanted to hide some important word documents so I zipped all the word files and created a zip file "word.zip"
Then copied both "myphoto.jpg" and "word.zip" to c:
Opened the command prompt
Typed the command: copy /b myphoto.jpg + word.zip new_image.jpg
Now I have a new file "new_image.jpg" in C:
When I double click on the new file it shows me the image of "myphoto.jpg"
If I change the extension of new_image.jpg to new_image.zip I can extract the contents of the .zip file
ENJOY !
ENJOY !
on Dec 03, 2009 | Computers & Internet
How do I undo read only on jpg files
Try this, right click on the folder that contains the JPEG files (.jpg) or right click on a certain JPEG image and scroll down the pop up menu and select "properties", then from the properties window look down at the "attributes" section and then un-chech the read only box, then select "apply", and then "Ok'.
Of course you will most likely have to be logged on as an administrator to actually change that. Here are some images to help assist you.
Sep 24, 2010 | Microsoft Windows® XP Professional Full...
We took pictures on our Fujifilm finepix S100 in raw format. We now cannot download these pictures to our mac computer. Help please. Our camera is a finepix s100fs
Raw files of any type can be a problem if you don't have a program to open them but, they should download to the computer the same as a jpg file format. Are you attempting to download from the camera to the computer or do you have a card reader plugged into a USB port? Image software such as Photoshop has the ability to open and work with RAW files also with the S100fs when it was bought is a "FinePixViewer" and a program to be able to edit the files. I can't use the Fuji RAW editor because it clashed with another program and I had to remove it. I use PhotoShop CS3 for my RAW files from the Fuji S100fs. Aside from all this it shouldn't stop you from creating a file folder for your image in "Documents" and placing those images in there for future use or editing. If you can download jpg then RAW should be no different.
Aug 07, 2010 | Fuji FinePix S1000FD Digital Camera
Inserting images into a flash website template
first make sure that your pics are the same file extension
(jpg,bmp,png ext)
if the original pic in the flv was named top1.jpg make sure that the pic you import is named top1.jpg
Aug 03, 2009 | Adobe Flash Pro CS4 for PC
The camera locks up
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.
  1. There are six screws holding the metal frame of the camera body together, two on each side, and two on the bottom. Remove all screws, pop the strap-hook plate (sorry, probably not the most technical term there), then gently lift the front plate off by pulling up from the bottom, and remove the back plate in the same fashion. These should come off relatively easily. This is what the camera should look like as you remove the plates:
    http://willwm.files.wordpress.com/2008/10/img-5340.jpg
    http://willwm.files.wordpress.com/2008/10/img-5342.jpg
    http://willwm.files.wordpress.com/2008/10/img-5344.jpg
  2. Now, looking from the top of the camera, you should see a small motor on the left side, as shown below (its beneath the cable with a 22 written on it):
    http://willwm.files.wordpress.com/2008/10/img-5346.jpg
  3. Take your screwdriver (or another small instrument) and gently try to rotate the plastic piece attached to the motor on the left side, as shown below:
    http://willwm.files.wordpress.com/2008/10/img-5359.jpg
  4. At this point, try placing the battery back in the camera (if you have removed it), turn the camera to one of the capture modes, and press the power button. If all went well, your lens should now be able to extend and retract properly.
Jul 15, 2009 | Canon PowerShot S2 IS Digital Camera
Games
cant have 69 iso...might be 69 rar files. In which case you have to unrar it to 1 single file. iso = image of something. It doens't make any sense to image something 69 times.
Try unzip/unrar it.
Jun 21, 2008 | Microsoft Windows XP Home Edition
Error message
Hi If you are in trouble about the placing jpg image in flash then open it photoshop or fireworks save as an other name.jpg and import or place in your working software
May 23, 2008 | Adobe Photoshop 7.0 for PC
How to convert jpg to pdf file...
Start your graphics processing software ( for example google picasa or as im demonstrating mircrosoft pait.
2. Open a JPEG picture document
3. Select from main menu "File"->"Print"
4. Select Printer "Virtual PDF Printer"
5. If you need to adjust PDF generation options, click the "Property" button on the right
6. Click "OK"
7. A dialog will pop up, assign the folder and file name of the PDF document to be generated
let me know if this helps
Feb 03, 2008 | ScanSoft PDF Converter Professional...
QuarkXPress Logo
380 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Michael Galve
Michael Galve
Laxman Bisht
Laxman Bisht
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
