Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
I have a CECT Phone i9 and the slide wont unlock...?
The power off slide works but the unlock want work.....help me out...
    Problem Solver:
  • 5 Answers
You can try to reload that particular file it might have been corrupted it happens with thoses phone under certain circumstances
Posted on Jun 26, 2009
How do i unlock my sciphone i9
The SciPhone i9 is not locked to a specific carrier from the factory. That is, it comes from the factory SIM unlocked.
Jan 27, 2010 | Dual Electronics CECT P168 Cellular Phone
Trying to set up internet and email on my I9 phone..
go to www.samsungmobile.co.uk . scroll down to where it says support then click on configure phone. click on wap or mms ( u will have to do both if you want both) then fill in details where it says phone model use samsung pixon ( u wont find cect i9 anyway) i did this and my works fine. hope this helps
Dec 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Cect i9 not working
Take the battery out, towards the bottom left are 2 slits (sim one and two)
The **** closest to the back is sim2 which the card goes in with the gold chip facing you, the other **** next to it is sim one, with chip facing away from you
Jun 23, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 cect
When you first get it or if you change it to factory settings it will do this until you change the pen calibration. Just keep working at it its just not very sensitive till you do that. I had the same problem but was able to get it so just keep working at it.
Jun 07, 2009 | Dual Electronics CECT P168 Cellular Phone
I purchased a unlocked cect i9 and it states to insert sim card how do i unlock phone?
This phone is NOT 3G compatible (it's just it's name ...) if your Tmobile card is 3G it will not work. All CECT phones are factory unlocked !
Jun 01, 2009 | Dual Electronics CECT P168 Cellular Phone
I9 Phone Unlock wont move
Try Calibrating the touch screen. Listed is the instructions how.
Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
Apr 22, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cect i9 slide to unlock will not open
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Jan 20, 2009 | Dual Electronics CECT P168 Cellular Phone
My i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
Jan 19, 2009 | Apple iPhone Smartphone
HOW CAN i FIX M I9 phone/
is it stuck..like the slide feature wont let you slide to get to the main menu??? Mine did this and it lasted for almost a day..i had top take the battery and sim card out and keep putting them back in and keep turning it off and on and eventually it became unstuck. and has worked since and not gotten stuck..if its not that then let me know..also
Jan 09, 2009 | Dual Electronics CECT P168 Cellular Phone
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
143 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
