Question about Craftsman Garden
The steering colum skips when you turn. Sounds
The steering colum skips when you turn. Sounds like it is skipping gears and will not turn the wheels.
  • jshaw02 Jun 26, 2009
    Model No. 917.270821
    Serial No. 090498DO28899
  • Dwain Pippen May 11, 2010
    What is the model number under the seat?
  • 376 Answers
You unfortunatly have the older style steering assembly and is not an easy fix. My best advice is to take it to a reliable shop to have the steering repaired. It may just need the bushings on the shaft replaced or the gears themselves, depending on the damage.
You can look down at the bottom of the steering shaft and see where the gears are skipping over each other.
Posted on Jun 26, 2009
Steering skips
Three things need to be checked. The steering shaft for play, the pinion gear on the end of the steering shaft and your stationary gear at the bottom. Raise the hood, turn the wheel back and forth so you can see where the play is coming from.
Aug 04, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Steering gear slips
You have the steering shaft the pinion gear on the end of the shaft and the stationary gear at the bottom on the frame. Either the gears are worn out or the steering shaft has too much play in it causing the gears to slip.
Steering wheel slips/feel notchy
Has belt been inspected, tension checked?
Mar 04, 2014 | 2011 Cadillac CTS-V
2010 Chevy silverado Rear wheel dragging on turns
if you have a limited slip differential or a diff locker in action , that is what will happen if the unit is locked up
if you do not have anything but a normal diff, it indicates gear failure and the side gears ( spider gears ) have metal in the teeth and are jammed
Dec 01, 2017 | 2010 Chevrolet Silverado 1500
Cub cadet lawn mower steering wheel will not turn all the way to the right. It turns all the way to the left, but not the right. Checked the teeth on the fan gear, all are okay. what next?
Even though the teeth on the fan gear are ok, they may have skipped past each other a few teeth. My tractor has a bushing that the end of the steering rod passed through before attaching to the fan gear. The bearing was worn, allowing the steering rod to move, and the fan gear would then to lose it's grip from time to time, eventually making my tractor perform much like yours. See if you can replace that bushing, your issue should be solved.
Mar 17, 2013 | Cub Cadet 50 In RZT Deck Belt 75404044
Steering only turn to left side
You will probably need to place the steering shaft gear and the sector gear and the lower bushing. The original cause of failure is likely the lower bushing where the steering shaft goes through the frame. It probably wore out allowing the shaft to move away from the sector gear allowing the gear teeth to skip on each other.
Oct 22, 2012 | Garden
If I have to turn my steering wheel or move it up and down for it to start whats my problem.
Sounds like a possible short inside the colum, I would check the ignition switch (key switch) if not that check the ignition switch from there check for a short in the steering colum.
Sep 13, 2012 | 2002 Cadillac Deville
Have sterring problem cub cadet lt 1024
i have been finding the plastic bushing that holds the steering shaft down into the other gear breaks or wears out that a look there
Aug 13, 2012 | Garden
My gear shift locked up
Did you leave the steering wheel turn to right or left? If so turn it to the way you left it as far as it will go then try to turn the key. Try this a few times to get it to key to turn. Also try rocking the car while turn the steering wheel and key might need another person. Cause: the park pin is ingaged and with the wheels being turned makes it hard to unlock steering colum.
May 14, 2009 | 1999 Ford Taurus
2001 ford escort, has a catch in both Directions when steering
check for low power steer. fluid,loose pow.steer.drive belt,defect.steering gear,
Mar 06, 2009 | 2000 Ford Escort
Garden Logo
466 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
