Question about Jandy AQUALINK RS TELELINK KIT
My Aqualink RS Wireless says Pool Heater Jandy Laars LX is offline. How do I get it online?
    Champion:
  • 246 Answers
AT THE HEATER PRESS THE BOTTOM TO TURN THE HEATER ON LINE IF NOTHING HAPPEND THE HEATER MUST DE WIRE CHECK YOU MANUAL FOR THIS ONE
Posted on Oct 15, 2009
The screen on the heater says service AGS. The heater will not work.
check to see if pressure switch is working should have 24 volts ac on both sides make sure firemans switch is closed aqualink calling for heat and correct gas pressure
Sep 15, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Unit starts to run and then goes into rs online mode disabling unit. checked for loose wires etc. rest button to go back to manual mode but goes back to rs online mode. is there way to bypass this and what...
make sure aqualink has heater enabled if not enable it if still doesnt work turn heater to off hold up button and down button and menu all at same time for 7 sec then you should be able to take it off remote and put on manual
Oct 07, 2013 | Jandy Laars LX Pool Heater / 250,000 BTU /...
Laars xl 400 heater off line
turn off aqualink then turn back on it should see it
Jan 25, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Does the pool pump need to wired into the Jandy heater for the heater to work?
no if using a aqualink yes firemans switch to pins 1 and 2 on long green or gray plug if no aqualink the pressure switch will turn it off
Jun 15, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Spa not heating up. Aqua link says Heater offline. How do we fix that?
turn off aqualink turn off heater then turn on aqualink then turn on heater it should recognize it also make sure red 4 pin connector is plugged in
Oct 11, 2010 | Jandy AQUALINK RS TELELINK KIT
My AquaLink RS8 control is reading "heater offline" . My heater is the Jandy LX. Someone said it might be the sensors, which are cheap to replace, any other ideas? I worked last week.
Could be sensors, dip switches, wire block connections or most often wire connections or bad wire since it is usually solid wire. Check where it goes through cabnit as this is a stress spot. Good luck.
Sep 23, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Heater is off-line
If you are talking about the RS Online indicator, this just means you are not hooked up to a "RS Control system" aka remote sensor or control. Does the heater work?
Jul 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy LXI gas heater. no power to the universal controller interf
wireless system to aqualink heater must be hard wired to aqualink by either 4 pin connector or firemans switch
May 09, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My aqualink says heater off line
What kind of heater? Is it a Jandy? Onb the digital board, there is a rubber button that needs set to pool or spa. It will say RS offline if this is the case.
Dec 11, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
839 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
