Question about NAD C372 Amplifier
NAD 302 PHONO STAGE
Hi everybody. I have a NAD 302 (not a 3020) amplifier which has a slight problem and I'm hoping somebody will be able to help. My record deck is connected to the phono inputs on the amp; the problem is that the right channel output goes silent - this can happen when it has just been switched on, or it works ok for a while then goes silent - sometimes switching the power off then back on brings the right channel back on but only for a short time. This never happens when any other source is selected - it only happens when I have selected phono input. So I'm guessing that the problem is in the phono stage ? or somewhere else within the amp ? any info would be greatly appreciated. Thanks.
    President:
  • 1,114 Answers
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Posted on Jun 26, 2009
How can I turn off the sleeping mode on the nad 3020
You may want to try this if you need a manual or other info.
http://www.hifiengine.com/manual_library/nad/3020.shtml
May 10, 2014 | NAD D 3020 Hybrid Digital Amplifier
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
Record player does not work
Hi, I don't think the amplifier has a mm/mc phono stage, I think it's an optional item.
You can buy one pretty cheap.
If you need more help , please ask
Regards - Anthony
Jan 31, 2010 | Cambridge Audio Azur 640A Amplifier
Need user manual for setup of the amplifier.
It should say next to the speaker terminals what impedance of speaker the amplifier is rated for. You can drive any speaker within reason with just about any amplifier as long as you are not trying to attain loud levels. Here is a link to the service manual for your amplfier. It states in the schematic power ratings for 2,4, and 8 ohm speakers so you can assume that this amplifier is compatible with those impedance speakers. NAD is generally known for their beefy amplifier sections. http://www.scribd.com/doc/7234868/NAD-3020-Service-Manual
May 03, 2009 | NAD C325BEE Amplifier
Denon 2802 amp
Dear Armani,
You cannot put de leads from an MP3 player or your TV into the pre-amplified connection of your Denon,
the phono "stage" is a low input stage, your input from MP3, TV, CD, DVD oscasetteplayer is high output (a 5 to 10 times stronger signal)
Try every other stage like tape 1 or 2, this will work just fine,
succes
Apr 30, 2009 | Denon AVR-2802
Phono stage
Hi. The phono input of your STRBD930 has a pre amplifier on it, and as such should only be connected to a dynamic phono cartridge. This is one which has a moving coil or magnet, as opposed to a piezzo cartridge. Connecting a piezzo turn table to the phono input will provide a too-higher voltage input for the pre amp, which might damage the pre amp. I hope this helps. PS moving magnet and moving coil are same difference. These are both dynamic cartridges, and can be connected to STRDB930.
Jul 07, 2008 | Sony STR-DB930 Receiver
Connect turntable to NAD S300
Yes you will need a pre-amp for your turntable, there is no phono input on this amplifier. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 08, 2007 | NAD S300 Amplifier
NAD C372 Amplifier Logo
555 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
