Question about Husqvarna 28cc Gas Line Trimmer
How do I change the string on a Husqvarna 128 LD trimmer?
evwood
  • 50 Answers
SOURCE: Husqvarna string trimmers 125c
Check for a spark. If none, then the coil is bad. Replace it. That should solve your problem.
Posted on Feb 14, 2009
steve_lima
  • 181 Answers
SOURCE: what are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Posted on Mar 12, 2009
  • 42 Answers
SOURCE: Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Posted on May 17, 2009
  • 8 Answers
SOURCE: my Husqvarna 128 LD bogs down and quits running
Dirty air filter, dirty fuel system, ie carb, lines, fuel tank. Poor air fuel mixture srew adjustments.
Posted on Apr 27, 2010
  • 5531 Answers
SOURCE: I need an owners manual
Try this PDF: http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_115275126.pdf .
I hope this helps.
Posted on May 05, 2011
Drive head rotates counter-clockwise. Can't get it back into position. Use to be able to simply turn it back around. Can't now.
Husqvarna 128 LD Weedeater Repair Questions,... - Fixya
www.fixya.com > Forum > Lawn Trimmers & Edgers > Husqvarna
Recent Husqvarna 128 LD Weedeater questions, problems & answers. Free expert DIY tips, ... Drive head rotates counter-clockwise. Can't get it back into ...
HOW TO CHANGE HEADS ON HUSQVARNA 128LD - Fixya
www.fixya.com/support/t20975899-change_heads_husqvarna_128ld
Oct 25, 2013 - Question about Husqvarna 128 LD Weedeater ... SOURCE: MyHusqvarna 128LD primer bulb .... Drive head rotates counter-clockwise.
Weed eater bogs out at full throttle - Fixya
Oct 07, 2015 | Husqvarna 128 LD Weedeater
How to change the fuel lines in the 128 Ld Husqvarna Trimmer
Buy some new fuel line then put the line in from the motor side into the tank and feed up and through the opening on the tank. Then you can put on a new filter with a tiny clamp then put it back into the tank making sure the filter is resting on the bottom.
Apr 22, 2015 | Husqvarna 128 LD Weedeater
HUSQVARNA 128LD WILL START RUN FOR A FEW SECONDS AND DIE.
You need to adjust your idle screws. Start at 1 and a half turns out for High and Low then go from there.
Aug 22, 2014 | Husqvarna 128 LD Weedeater
Husqvarna 128cd starter rope will not retract
Sounds like a problem with the recoil spring, remove the pull start assembly and check the spring. (be carefull, they have a tendency to jump out in your face)
Sep 10, 2012 | Husqvarna 128 LD Weedeater
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
Stringing a husqvarna weedeater
The 125LD had a T25 bump feed trimmer head, depress with finger and thumb the tabs either side of the head, the base will then pull away with the white centre spool, take a lenght of 2mm cord, bend in the middle so as you have two equal lengths, hook the bent end into the cut a way in the spool and wind both lengths in the same direction as indicated on the spool, once you have enough cord on the spool secure the ends in the slots on the outer edge of the spool to stop it all un raviling, place the spool back into the spool housing, carefully place the cord through the metal eyelets, push the assembly back into the upper housing clicking it back into position.
Jul 05, 2012 | Husqvarna 128 LD Weedeater
Husqvarna 28cc Gas Line Trimmer Logo
1,892 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
