Home | Pressure Washers | Engine starts, runs for...
Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
Engine starts, runs for 10-15sec. then shu...
By oakmo1 on Jun 26, 2009
Engine starts, runs for 10-15sec. then shuts down. Any thoughts.............
Clarification Request
Posted by protek480 on Jun 26, 2009
Low oil pressure (or bad oil pressure switch)
Best Solution
posted on Jul 05, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 7036 votes
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions.thankyou ^^
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
My pull cord to my pressure washer is hard to pull and it's not starting. Why? This all started... (More)
Answer
The on-off switch shaft broke on my K 2.89 M pressure washer and I can't get the broken piece out.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pressure Washers:
Top Pressure Washer Experts
Rank: Guru Guru
Solutions: 3639
Experience: ten years experience,school trained,own business
Ask Me
Find more Pressure Washer Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
