Question about Dishwashers
Dishwasher soap residue
Recenly, our dishwasher does not rinse all the soap from the dishes. Either powder, or liquid, the soap is still there. Also tried using 1/2 the amount of soap, with the same results.
  • johninge Jan 05, 2008
    We recently bought a Bosch SHX98MO5UC. We were really disappointed and
    the dealer took the machine back. It washed, but never rinsed. After
    3 weeks of back and forth, making it all sound like we are the stupid
    ones and don't know how to use a dishwasher, we were done. Will never
    buy another Bosch, because of their attitude. They finally conceded
    that the Circuit board might be at fault, but by then we did not want
    the machine anymore. We are now buying a Miele. Done with Bosch.
    Their customer service is terrible and our local dealer, who was very
    nice, is very embarrassed.
  • Anonymous Dec 01, 2008
    I have the same problem. If you pull the filter and the traps from the back of the dishwasher, I bet you will find that there is soap residue built up. I dont know how to fix that. sorry.
  • 81 Answers
SOURCE: Soap still in dispenser and dishes dirty after dishwasher is ran
Your description sounds like the water pump is wearing out. Call the repairman.
Posted on Apr 24, 2009
SOURCE: dishes not getting clean
I just fixed mine that had the same problem. It turned out to be the red rubber check-valve just inside where the drain hose attaches to the bottom of the motor. This check-valve, when operating properly during the drain cycle, will only allow water to drain out. During the wash cycle, it will prevent dirty water from the p-trap from being sucked back into the dishwasher. If this check valve gets dislodged or stuck open, dirty water will get sucked back into the dishwasher during the wash cycle, leaving dishes dirty and, perhaps, water left in the bottom. First, detach the drain hose from the p-trap and place in the sink or in a bucket. Turn the washer dial on and make sure the water does drain out and fully empty the water from the dishwasher. If not, you may have blockage in the drain hose. You can vac this out with a wet vac if needed. If you can successfully drain the dishwasher by clearing the drain hose, then pull the dishwasher out, place it on it's side and detach the drain hose from the motor. You may need some towels! Ensure this rubber valve is seated properly and reattach the hose. Hope this helps, it worked for me.
Posted on Nov 28, 2006
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at
Posted on May 21, 2008
  • 163 Answers
SOURCE: Subject is Bosch dishwasher SHU6800.
It cleans poorly If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Posted on Aug 17, 2008
  • 677 Answers
SOURCE: my viking dishwasher does not rinse the soap scum off the dishes
Its not soap, its actually calcium from hard water. There is a new product out at that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
My Samsung model #WA4H7000AW/A2 seems to always need an additional rinse to get rid of soap left behind. Is this a common complaint ?
Here are some questions that may help.
1) Is the water hot enough? Since the soap "melts" better at higher temperatures, cooler water can leave a soap film.
2) Are the dishes clean before you run the machine? We like to used the dishwasher to "sanitize" the dishes, so we rinse them really good before washing them, to get off caked food residue.
3) Try changing washer soap, try powder if you used liquid, or visa-versa, and try less quantity and see if any of those help.
God bless your efforts.
Dec 19, 2016 | Samsung Washing Machines
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
When I run my dishwasher I find the soap cube lying in the bottom of the machine after the full run cycle and the dishes just get a rinse
Is it possible your dishwasher can't use soap cubes? I have seen powder and/or liquid specified.
Feb 25, 2013 | Maytag Dishwashers
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
Apr 25, 2011 | KitchenAid KUDS50FVSS Builtin Dishwasher
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
The dishes do not rinse properly--despite rinse
run some calcium lime and scale remover throught the unit on an empty wash cycle just to get rid of any build up that may be there.
turn the rinse aid down to about half way.
also check the phosphours content of you washing agent.
there is a lot of factor involved with leaving film on the dishes, it could also be residual soap content that is sticking to your dishes.
reduce the amount of soap a little.does not matter if it is liquid or powder.
once every three months you need to run cleaner through the machine.
last thing but very important make sure the incoming water temp i no lowe rthan 120 degrees.
Jun 09, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
Extra suds due to liquid soap in the machine overflowing. How do I drain it?
This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
Mar 18, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Soap not fully rinsed from dishes, maytag quiet series 300
Mar 12, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
After the dishwasher cycles, there is white residue (looks like the detergent) on some of the dishes. i have tried different kinds of detergent with the same result. does this have to do with the "rinse...
you have a temperature issue. the soap has to dissolve when it gets above 120 degrees. you should be using the water heat option, sometimes called the water heat added, or high temp wash. use this cycle and then do not over do the soap. only use the smallest amount and always use dry powder, do not use liquid or tablets.
make sure that there is a rinse agent in the dispenser. it does not have to be full but does need to have some in it.
Jan 03, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Dishes not getting clean
the problem is hard water leaving the residue. go to and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Dishwashers Logo
658 people viewed this question
Top Dishwashers Experts
