Hold down (Fn) key and press, press, press.... right arrow (----->) the right most key on your keyboard until back light brightens. If you press several time it also goes off. Just press again until brightens.
Have fun
SOURCE: Dell 19" Monitor - Dead
go to lcdrepair.us you can buy the board you need there , you can talk to tim he can help you out or email him
SOURCE: Height adjust for Dell UltraSharp 1907FP 19" LCD Monitor
Is it stuck, or just not adjustable? Try setting it on a phonebook. I'm kidding. If it is an adjustable base, sometimes they need a little downward pressure before the button will depress and allow it to move upward.
Thanks,
Chris
http://BoiseLCD.webs.com
SOURCE: dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
SOURCE: Hi Team, I have Dell Ultra Sharp Monitor which
If you are not an electronics tech It would be remiss to advise you to interfere with a high tension device like a monitor. take it to where it can be serviced and keep your life. Only experienced people should open up a monitor and poke around 22000 volts is involved here and if its overheating the wiring on th ecoilod ids breaking doen or has broken down.
