Question about Coleman Powermate 60 Gallon Air Compressor
Sparking brushes sparking at the brushes of my campbell hausfield air compressor. could it be problem or is it my motor?
I have a 6.5 hp two stage coleman magnum force 80 gal compresur I had to replace the switch with a presure switch from grainger. Now the motor sounds like it is dragging when it starts then blows the capacitor apart. Any sugestions I am questioning if i have wired it wrong or not.
Posted on Jul 23, 2009
  • 146 Answers
Try blowing out motor i have used a armature cleaner like acetone while motor is unplugged or just replace brushes
Posted on Jul 08, 2009
Compressor problems when filling tank
There should be a device called an "unloader " connected to the machines own switch. This releases the pressure from the compressor so it can start up without the resistance of the pressure in the tank.There should be a hissing noise when the machine stops, the sound of the air on the compressor side of a non return valve being released.
Jun 03, 2010 | Campbell Hausfeld 13 HP 30Gallon Air...
I bought a HS5180 air compressor from WW Grainger. I lost the manual, and directions to install. Can you please email them to me? Thanks Jeff
Jeff, you can go to the Campbell Hausfield website, and download all of that. You can save it as a PDF file, and just print it yourself.
Apr 08, 2010 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
My campbell hausfield wl660001aj will not come on and I changed the fuse also. 5 gallon vertical
Water is condensed from the compressed air it makes and this can settlel in the switch diaphragm, in cold weather is can freeze and prevent the switch from working.....
Feb 02, 2010 | Campbell Hausfeld Air Tools & Compressors
Wanting to adjust my cut off pressure down...its at 135 now but have in line tank, campbell switch 60 gallon
If I read your problem you would like to decrease your pressure setting on a campbell hausfield compressor, this usually can be done by turning the 3/8" nut (typical) counter clockwise which decreases the spring tension on the pressure plate allowing less pressure to break the points. Hope This Helps Don
Dec 02, 2009 | Campbell Hausfeld Air Tools & Compressors
Air compressor not working, campbell, hausfield turns on but doesn't make loud noise it used to seems like it is not kicking in. It just sounds like a loud vacuum cleaner. Campbell Hausfeld WL6501 13...
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Apr 11, 2009 | Campbell Hausfeld Air Tools & Compressors
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Wiering
look at the motor nameplate it should have voltage and fla which is full load amps this should be calculated by an electrician for wire size hope this helps
Aug 05, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Coleman Powermate 60 Gallon Air Compressor Logo
406 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
