Question about Refrigerators
Kenmore - Ice Maker Not making much ice
My icemaker is making very little ice. It's been working for a while now, but all of a sudden the ice production slowed a lot. Any suggestions? I've checked the water supply and everything looks good there. The "teeth" in the maker are rotating on a regular basis, but there's no water in the trays. Again, this just happened all of a sudden.
  • rapeay Jan 17, 2008
    The saddle valve was bad. Replaced with new saddle valve and ice maker now works perfectly.
Check water inlet valve on your frig
Posted on Jan 17, 2008
I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
Here is a link for the control module.
Here is a link for the new ice maker.
Oct 15, 2012 | Kenmore Refrigerators
Ice maker not working doesn't fill or dump or make any noise, stopped suddenly
Make sure the lever is down first . if so ,pour about 1/2 cup of water into icemaker and see if it harvests (dumps) . If it harvests , then the water valve is bad . If not , and the ice stays in the icemaker , then the icemaker is bad .
Jul 12, 2009 | Kenmore 64522 Top Freezer Refrigerator
Ice maker not working on kenmore top moun t freezer
Suddenly my icemaker stopped making ice. I have a Kenmore ref. with a top freezer.
May 09, 2009 | Kenmore 64802 Top Freezer Refrigerator
Can not make ice. Ice maker was working until husband cleaned it. thank you.
Is the little on-off bar attached to the icemaker in the "on" position? It is the device that will not allow the icemaker to cycle when the ice bin is full...
Mar 02, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working properly
Make sure the fill tube going directly into the icemaker is not touching the part that receives the water, if it is touching the water will spray all over and not go into the cavity
Jan 11, 2009 | Kenmore Elite HE4 Electric Dryer
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Apr 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Mar 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
402 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
