Can it be unlocked to be used on any network?
SOURCE: can i unlock nokia 233oc
If your phone is activated, the code should be the last 4 digets of your phone number.
SOURCE: i m using nokia 2330c-2 how can i remove
Hey,
You can refer the manual from the link below http://nds1.nokia.com/phones/files/guides/Nokia_2330_classic_en.pdf
Go to display settings and then Power saver clock you can select Digital clock, Classic clock or Off
Let me know if this will help
Regards
SOURCE: please I need the restriction code for Nokia
i have the problem of restriction code in cell phone nokia 2330c-2
IMENO 358263/03668629/5
SOURCE: how do i get the unlock code for Nokia 2330c
You can get the unlock code at here
Mobile-unlocker and Unlock the Phone from network lock......You can follow the instructions below and enter the code in the Phone,You need to specify the Network,Country it locked now?then you can order code and Unlock it.
Warning : Do not enter any wrong unlock
codes on your Nokia 2330 Classic mobile phones. If you enter over a
certain amount of wrong unlock codes on your Nokia 2330 Classic mobile
phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 2330 Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 2330 Classic.
3 - Compose #pw+CODE+1#.
4 - The Nokia 2330 Classic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 2330 Classic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 2330 Classic
SOURCE: unlocking my nokia 2330c 2 IMEI
To Unlock The Nokia 2330C 2 use the Unlock code,Specify the Network and Country it locked now?get the unlock code at here Prounlocking.com/nokia/rs8wp8/ and Unlock it
