Question about Whirlpool Washing Machines
Washing machine stops after final rinse cycle
Hi. I have a Roper by Whirlpool top loading washing machine. I just began having a problem with it las night. It stops after the final rinse and does not drain or go into the final spin. When I manually advance it, nothing happens. Last night, I kept turning and pulling the knob over and over again and it finally drained and spun. Now, it's stuck again with a new load in it, and I can't get it to drain no matter what. I even ran the load again a second time from the beginning and it just stopped in the same place. Any suggestions? Thank you.
  • Whirlpool Master
  • 3,361 Answers
Your lid switch is bad. It must be replaced.
Posted on Jun 26, 2009
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Whirlpool washing machine top loader will not rinse or do final spin
If your machine fills and agitates through the wash cycle and then stops, check the lid switch.
http://www.youtube.com/watch?v=bV8C6aLBL9w
Mar 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle of Roper wash machine-Whirlpool won't work.
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 18, 2010 | Washing Machines
I have a Roper washer. It filled with water to wash, but when it came to draining the water to rinse, it just stops. It will add water on rinse cycle, but it will not drain or spin.
Sounds like the lidswitch. As a safety, the tub will not spin if the door is up (open). In turn, it will not drain if it wont spin. This is a common problem with whirlpool washers. You can go to searspartsdirect.com to get the breakdown and order the part.
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Roper washer stops at rinse circle
Turn off your water to the washer.
Remove the hoses from the valve at the rear of the washer and clean the trash out of the filter screen.
You have a cold fill rinse washer.
If it can't get water it stops advancing the timer.
Mar 08, 2009 | Whirlpool LSB6200KQ Top Load Washer
Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Sep 21, 2008 | Whirlpool LCE4332P 2.1 cu. ft. Top Loading...
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Washing machine stops at rinse cycle
Sounds like a faulty lid switch. The switch will not allow this unit to drain/spin if the switch is faulty.
Jan 05, 2008 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
129 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
