Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Often the printer prints the copy backwards (mirror images). Then it will revert back to printing properly. HELP!!!
  • 952 Answers
To resolve the issue, turn off mirror imaging in Printer Preferences . To do this, use the following steps:
  1. From the Windows taskbar, click Start and then click Run .
  2. Type control printers in the Open box and then press Enter . The Printers and Faxes window displays.
  3. Right-click the HP product from the list of printers and then select Properties . The Properties dialog box displays.
  4. From the General tab, click Printing Preferences . The Printing Preferences dialog box displays.
  5. Click the Advanced tab.
  6. Under Printer Features , click Mirror Image , click the down arrow to the right of the field, and then click Off .
  7. Click OK to apply the change.
Posted on Jun 26, 2009
PRINTING BACKWARDS
Go to Start>>Control Panel>>>Printers.
Select Printing preferences.
Go to Advance Tab.
Select Mirror images and turn it off or uncheck it.
Press Apply and OK to Apply the settings.
Also perform the same steps on Solution Center.
Open HP Solution Center.
Go to Settings>>Print Settings>>Advance Tab.
Mirror images=OFF
Jun 01, 2010 | HP PSC 2210 All-In-One InkJet Printer
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printing backwards after installing vista service
click on start > control panel > printers or printers and faxes >
right click on the printer icon and select printing preferences.
click on advance and look for mirror image
turn off mirror image and click apply.
this should work
Oct 27, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printing in Mirror image
It's likely that you have an old outdated printer driver for your L7590 as this has been a long "known" issue with the L7000 series of MFD's.
To resolve the issue properly you need to uninstall the current driver version and then download the latest version of the software that isn't just driver/basic based.
You can extract the source files including the drivers folder using 7zip if you want to try and avoid installing all the additional bloat that comes with these printers.
Failing that, you need to define alternative quick settings to take over from duplex (two-sided) printing as this appears to have been incorrectly set to use mirror printing. Other quick settings have been implicated as well but the driver update should resolve all of them.
In some instances the driver update doesn't apply properly so you may need to uninstall and reinstall more than once... Remember to delete your printer from the printer listings and unplug it from the USB cable before you uninstall and reinstall to get it to work properly.
Hope this helps.
Martin
May 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Printing documents backwards
You must have set it to be a mirror copy in the print settings.
Oct 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Prints text backwords on text files
click on start go to control panel
click on printers and under printer look for the printer icon
right click on the printer icon for your printer and select printing preferences
try to print afterwards
Oct 20, 2008 | HP Officejet J5780 All-In-One InkJet...
Printing backwards
When you get the print window, click "Properties", then click on the "Advanced" tab. Look for a "Mirror Image" menu item. It should say "Off". If not, click on it and you should get a drop down box to change it to off.
Oct 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Printing Backwards like a mirror image
You need to change the printer properties.
You can do this a few ways:
  • Click File , Print , then click the Properties button.
  • Click File , Print Setup , then click the Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
  • Click the Taskbar Printer icon.
  • Right-click the applicable 3740 icon in the Printers folder, then click the Printer Preferences button.
Click on the "Basics" tab.
The 3rd option under "orientation" will say "mirror image".
Make sure this is un-checked.
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
41 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
