Question about Technics SL-1210 Turntable
No power to Either technics 1210. Motors have been replaced and still no difference, fuses checked all OK. Not very skilled with electrics, so does any one no any places in Essex that repair decks?
  • 69 Answers
Have u checked internal fuses,theres one that protects the transformer an one that protects the main board.if both decks have gone maybe a sudden surge of power could have caused them to go?i had a the same problem quite easy to check really m8.
remove platter unscrew the 5 plate screws an remove.then put a multimeter on the fuses,might be able to even see if there gone.
important u change them for the right fuses though, can be picked up from any electrical whole salers ie rs components.gd luck
Posted on Aug 06, 2009
    Scholar:
  • 113 Answers
Hi surprised that both stopped!!
Are they plugged into a transformer of any sort, if so, there could be a problem with that.
Posted on Jul 22, 2009
  • 33 Answers
Hi there... you have to replace the transistor Q2,Q3 ...and then see what happen while you change..u
Posted on Jul 09, 2009
  • djsherwin_29 Jul 12, 2009
    try to check the tansistor Q2 and Q3..near around the motor of your turntable..
F1 Blowing after replacing RCA cable Technics
ability to switch between 110 and 220 voltages. is it set at the wrong setting to power on? why did you need to replace inside wires? maybe something was touching inside and has blown the fuse. see legitimate repair shop.
Sep 11, 2012 | Panasonic Technics Sl-1210 Mk2 Turntable...
I have a 2008 MKZ and the driver power seat suddenly. Quit working. The main fuse is OK and the control switch checked out good..is there a secondary fuse. Or does th)e motor need replacing
When you toggle the switch to the different positions of seat movement do the motors receive power? Also if one or more of the motors (there are 3 I think) is defective they are not available separately, you must replace the entire power seat track assembly.
Apr 10, 2012 | 2008 Lincoln Mkz
My 1210 turntable is slowing down/speeding up, so as the song sounds out of tune....what is the problem, and how do I fix it?
over time the motors go. you can replace it but its nearly impossible since they no longer make or manufacture technics due to controllers taking over the dj world.
May 08, 2011 | Technics SL-1210 Turntable
No Power to turntable
Why not try replacing the whole power chord with new one instead of just changing the fuse ( but you will have to splice the two wire lines at the end of your turntable console if not to resolder it, and be sure to properly mask it with an electrical tape to avoid electrical hazard/shock to anyone... ;-)
May 24, 2009 | Technics SL-1210 Turntable
No Power to 1210s
Problem is not the fuses, but the power supply / power transformer has blown. This is why you should always wrap exposed wiring with electrical tape or heatshrink tubing.
The power supply can be purchased HERE, but this is not an easy replacement. And if you blew it by not properly replacing the Pop-up light, than I DON'T suggest you try to replace the power supply on your own either. You could really cause even more damage, and possible harm to yourself and your property.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Nov 22, 2008 | Technics SL-1210 Turntable
They wont turn on
Check the fuses. If the fuses are good, then it's the transformer that is shot. The fuses are located underneath the turntable platter. If your unit does not have any fuses, then the only problem could be with your transformer. You can PURCHASE A REPLACEMENT TRANSFORMER HERE.
Good Luck!
- Davis.
DIGITAL ANALOG THERAPY
Jun 05, 2008 | Technics SL-1210 Turntable
Technics 1210 Distorts
Well, if it's not your tonearm, then the issue is either your RCA cables (red/white), or your cartridge/stylus.
There is nothing else on this unit that would cause distortion in sound. Well, unless you have the unit sitting next to a very powerful electrical source. Try a different outlet as well, just to be on the safe side that it's not electrical interference.
- DJ PRO LAB
www.DJPROLAB.com
May 01, 2008 | Technics SL-1210 Turntable
How do i replace the phono leads on my technics 1210?
OK,
you have to turn it over, remove the rubber housing, remove the round metal guard from below...
ONLY DO THIS IF YOURE CONFIDENT IN SOLDERING SKILLS!!
You have to unsolder 4 leads ( stereo ) and solder on a new pair.
If you actually proceed, i can give you a better step by step.
But this process requires soldering..so.
Keep me posted.
Oct 30, 2007 | Technics SL-1200MK2 Turntable
No power
With a voltage meter, open the table back up to where the fuse is under the on off switch. With the table plugged check the voltage meter check the incoming ac prongs for 20V. Also, the 1210 has a voltage switch under the platter to the left
 a little hole for which a flat head screwdriver is needed to switch the voltage. If you live in the UK or outside od the USA it should be on 220V, IF YOU LIVE IN THE USA, IT SHOULD BE ON 110V. If your electricity is 110/120 and its on 220, the transformer is most likely fried. If your electricity is 220V and its set to 110V , then its not getting enough current. Its possible the transformer could have gone bad, with no smell of burn or sign of damage. Also, check board with all the capacitors on it around the motor, check fopr any leakage...
If service Technics for 15 years and sometimes i'll se voltage issues I've never seen before.....
Oct 27, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
377 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
