Question about Canon PIXMA MP160 All-In-One InkJet Printer
Blurry printing After adjusting printhead alignment, some things are still printing blurry. Problem occurs with some (not all) Microsoft Word documents and some (not all) pdf's.
  • nicole_em Jun 30, 2009
    I appreciate the help, but I've had this problem for a while despite having recently changed both ink cartridges.
    Problem Solver:
  • 20 Answers
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi2
Posted on Sep 05, 2009
    President:
  • Canon Master
  • 1,447 Answers
Your printer cartridge is black ink is run out change it and solve problem
Posted on Jun 28, 2009
  • Sazeed Computer
    Sazeed Computer Jun 30, 2009
    You print all text black or grayscale
Why is the print coming out blurry
I suggest you perform a printhead alignment procedure.
Nov 15, 2016 | Office Equipment & Supplies
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Print is blurry
Hi
Check the ink levels on the cartridges and replace dry cartridges.
Also,try cleaning the 'printhead'
Feb 26, 2012 | Lexmark X3650 Printer
How do i align my printer, it's printing blurry but copies fine
the problem is with the main board. I fixed two of the exact same problem before.
May 28, 2009 | Brother Multi-Function Center MFC-240C...
I have a X7170 it has recently began printing with vertical blank areas on the printed copy. In other words up and down on the page there missing copy. I have changed ink cartridges and this does not help....
Uneven vertical lines can be adjusted by
performing the printhead alignment adjustments.
The user is directed through the Lexmark Solution
Center to perform the printhead alignment
adjustments when replacing a printhead cartridge.
The alignment can also be performed from the
control panel by selecting the Maintenance Option,
then Align Cartridges.
Feb 01, 2009 | Lexmark X7170 All-In-One InkJet Printer
Brother dcp 150c pinting out of focus / blurry
YOu need to Do Print Test First I suspect One of the Color have Missing Dot..If the Print Quality have missing dot on The 4 colour the print our will blur ....The aligment of the print head maybe swicted ......Need to Be purge Or Replace new print Head...usually print head needed to be replace...
Nov 01, 2008 | Office Equipment & Supplies
Blurred printing
You should be able to re align the printheads using the software package on the computer which you installed whenn you installed the printer
Jul 22, 2008 | HP Office Equipment & Supplies
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Print alignment
Did you set the No. after the alignment print? The prob described is definitly a alignment prob. In case you cant do good by setting the right no. after alignment print the printhead has to be corrected by service personel only.
Oct 21, 2007 | Brother MultiFunction Center MFC-440CN...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
500 people viewed this question
old marine
old marine
