New Frigidaire 15,000 AC makes knocking sound
My Frigidaire 15,000 BTU window AC, about three weeks old, makes a knocking sound. How can I be sure this is part of the ''normal sounds'' described in the manual--the pinging and clicking you hear when water drops hit the compressor? The machine has large vents on top where I can imagine some object might have fallen in--maybe I can look in there to see. Any suggestions on what to do before calling a service person? Thank you!
  • Heating & Co... Master
  • 19,622 Answers
Knocking happens when the compressor is faulty. The clicking is often the overheat Klickson switch clicking on and off. If is three weeks old, call it in under warranty.
Posted on Jul 10, 2017
jsrock516
  • 5911 Answers
SOURCE: whirlpool type 111 cp1915409 top loader
A few things may cause a grinding noise during the spin cycle. If the washer fills normally, but when it starts to AGITATE or SPIN, it makes a noise, this is usually caused by a bad motor coupling, bad transmission, basket drive assembly, or drive motor that's starting to fail. I also wouldn't rule out the clutch. It's really hard to tell without being there to see and hear what it is doing. I would also hate to tell you to call a repairman, but it may be wise in this situation because, even if you DO know what the problem is, it may be beyond your capabilities to repair. I could give you step by step tips on how to replace the parts, but diagnosing the CORRECT one would be the challenge. I hope this helps you some. PS The likely suspect in this case would be the transmission. Not a guarantee, but a guess.
Posted on Jul 22, 2007
  • 49 Answers
SOURCE: Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Posted on Nov 18, 2007
mrgrzz
  • 88 Answers
SOURCE: New 14 seer split ruud heat pump makes very loud knocking noise
Well you may want to have a tech come out and check the freon level, but mostly when going into defrost, some units make alot of noise, the freon is reversed in the unit by way of the reversing valve, it makes a whooshing sound like freon is draining off, as far as the knocking noise, could be as I said in the beginning, might be low on freon, but it could be that, this particular unit does this, I have had units make some really strange noises in the past but functioned perfectly, hope this helped, please let us know, thanks again,
mr.grzz
Posted on Jan 24, 2009
bobicehouse
  • 1524 Answers
SOURCE: Air Conditioner from upstairs neighbors condo makes water sounds
Time for a new unit. End of sentence.
Posted on Apr 26, 2009
  • 148 Answers
SOURCE: AC not stops working when compressor starts.
how many amp service do you have in the house
Posted on May 17, 2009
15,000 btu roof mount 2nd ac nonducted cycles about every 5 or so mins ice cold air for about 1 mins
Have you checked location of probe for return air? Remove filters and find probe to make sure it is about in the middle of flow of return air. Let me know what you find.
Jan 12, 2013 | Dometic Rooftop RV Air Conditioner
I have a new motorhome and the air conditioner only reduces the inside air temperature by 2 degrees on a hot day. e.g. outside air temp 26 degrees inside temp 29 degrees. After 2 hours of a/c running with...
Can you tell me what size/make of motorhome you have? Certainly doesn"t sound right to me, and I've been working on them for over 15yrs. Whether it's a 13,500 BTU or 15,000 BTU, it should be plenty as long as motorhome has any insulation at all. I assume you have central air from ceiling?
The manufacturer usually states that the AC unit will supply 20F below ambient.
Is compressor staying engaged all this time?
May 22, 2011 | Dometic Rooftop RV Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Brand new (3 weeks old) 14K btu Frigidaire blows cold on and off. Serviceman came out (when it was working) and found nothing wrong. Are they just junk or what?
No sometimes the problem is intermint if it just three weeks old take it back for a new one. Dont wast your time for a service call, its cheaper ti repace.
Jul 17, 2010 | Frigidaire FAH146R2T 14,000 BTU...
Mr slim ductless ac choices
Try this Air Conditioner Sizing Worksheet from Consumer's Reports. It will help you.
I hope you find this information to be very helpful to you moving forward.
Please leave a rating. :-)
May 09, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
Aug 18, 2009 | Frigidaire Heating & Cooling
I have a 15,000 BTU A/C unit 110v through the
take it back and get a replacement, sounds like it had a hydrolic action on the pump and blew the pump so get it replaced at no cost to you. It happens.
Jul 22, 2009 | Heating & Cooling
Noise
Adding cloth or any other sound absorbing material will not work. There is not enough room to add anything appreciable in the fan area.
Jul 22, 2008 | Frigidaire FAC107P1A Wall/Window Air...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
