Question about iLO (2 GB) MP3 Player
How do I remove write protect on my pc?
I have a dual-tier formatted removable Universal Serial Bus disk drive, and it says it is write protected! How do I remove write protection?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 64 Answers
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
Posted on Mar 22, 2010
Sir my pen drive is no format it is show is write prodected
Download this tool it will help you:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=MTX-UNITY-I23839
Feb 07, 2013 | Kingston Data Traveler 100 G2 4GB USB 2.0...
Can't open my sand disk
Is it password protected ?
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers.
If you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts .
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box.
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7.
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
Click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
or if its password protected
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
hope this helps
Nov 14, 2012 | Computers & Internet
USB disk not found!/ USB drive write protected, when formatting USB drive
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver or scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Nov 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove if the universal serial bus is in write-protected?
TRY TEST DISK file:///D:/testdisk-6.11.3.win/testdisk-6.11.3/documentation.html
Mar 30, 2010 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Windows was unable to format my flash disk
It seems that the card is bad. Try to format the card on a different machine to rule out your Windows formatter.
Aug 19, 2009 | Dell Inspiron 6400 Notebook
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Remove Jet Flash Write Protection Insert the mini CD that came with the USB Flash disk. Start JF Utility.exe in the JF Utility directory. If it complains that the disk is write protected, choose "Continue" Choose "Partition" Answer "Yes" to losing all your data (Since this becomes a problem usually after formating the disk in WinXP or Win9x, you will most probably not have any data on there in any case) Choose "Public Area Only (Single Partition)", Then "OK", Then "OK" again. Unplug the device, reinsert device, and voila!- no more dark secret areas or write protection on your disk!
Oct 06, 2008 | Transcend T.sonic 610 MP3 Player
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your Pendrive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your pendrive.
Aug 10, 2008 | Buffalo Technology 250GB USB SATA 2.0 HD...
iLO (2 GB) MP3 Player Logo
121 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
