Question about Frigidaire Ovens
Frigidaire Oven - lights are on but no heat from oven or burners
Heya folks!
I have a Frigidaire Oven model # FEFL64FSD
I am able to set the clock, lock/unlock the door, set bake temps and the clock, however the bake and broil elements inside never heat up, not even warm to the touch. The same goes for any of the burners and warmer on the stove top..
From all outside indications, it should be working... the control panel functions fine, the lights indicating the bake and preheat come on, and for the burners the lights indicate they are on. But alas, nothing ever
When initially plugging in the stove, there is a brief ''buzzer'' sound, then the clock flashes and can be set normally...
No ''F'' codes are displayed at any time.
Here are some pictures if that helps too..
http://img200.imageshack.us/i/20090626001.jpg/
http://img4.imageshack.us/i/20090626002.jpg/
http://img189.imageshack.us/i/20090626003.jpg/
http://img520.imageshack.us/i/20090626004.jpg/
http://img43.imageshack.us/i/20090626007.jpg/
http://img43.imageshack.us/i/20090626008.jpg/
Ideas? Suggestions? ECU gone bad?
  • webdeveloper Jun 26, 2009
    Thank you for the feedback and help. After reattaching the rear panels and plugging in the oven everything seems to work fine now. Suspect a loose 220v wall plug was in play as per Jumptrout51!
  • Frigidaire Master
  • 3,361 Answers
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Posted on Jun 26, 2009
Why can't i set the temperature on my frigidaire oven model # FFGF3053LSC? Burners work. I have unplugged it and plugged it back in. I have checked the circuit breakers. It still does not work. ...
Good Afternoon Annette,
I see that you are having trouble setting the temperature on your Frigidaire oven, model# FFGF3053LSC, even after resetting it by unplugging it. First I would make sure that you are able to set the clock as well. Try setting the clock by pressing the clock button and then pressing and holding down the up or down arrows to change the time. If you are able to do this and not set your oven, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why you are unable to set the temperature for your oven. Hope this helps.
-Best Regards-
WP
Apr 25, 2014 | Frigidaire Ovens
My Frigidaire electric range wont work (burners and oven)
The clock display works on 120 volts but the burners and oven require 240 volts. I would check the breaker or the receptacle to see if they're bad.They may be supplying only 120 volts. One more less common problem could be the terminal block on the range where the power comes in. Very rarely they will melt. BE SURE TO UNPLUG THE RANGE if you have to check the terminal block. Hope this helps.
Feb 12, 2013 | Frigidaire Ovens
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not heat. all the burners on top work fine. what could be wrong?
Usual faults in this order are:
Faulty oven element - check element for holes, blow marks etc;
Burnt off wiring at the oven element terminals - check terminals;
If the oven indicator lights when the oven is turned on it should be the above. If it does not refer below;
Electronic clock set to auto. mode instead of manual mode.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
549 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
