Question about Konica Minolta DiMAGE Z6 Digital Camera
My Minolta Z6 used to take clear pictures. Suddenly almost every image became is blurry. I then stored for about a year, now I have cleaned the lense to no avail. Focus l through lcd screen is also now blurry.I used it on an island
I think you may be doing what I have ben doing. The auto focus beam I think emits from the small sender between the hand grip and the lense portion of the camera, ( Bad Design) When gripping the camera my fingers sometimes block the sender and causes it to be blurry as in not focused. .Try to keep your fingers from going in between the grip and lens and I think it will work for you.Let me know if this helps. I am so glad I found this out because this camera takes nice pictures.
Bob zeisjr@aol.com
Posted on Sep 08, 2009
Blurred numbers on Bushnell range finder.What's the problem?
Bushnell V3 display question - Toronto Golf Nuts - Greater Toronto ...
www.torontogolfnuts.com > Golf Discussion Forum > Golf Gear & Equipment
Apr 8, 2014 - 22 posts - ‎3 authors
Bushnell V3 display question Golf Gear & Equipment. ... When I start it, the numbers are clear but it does not stay like that the whole time. ... Yea I used that and turned all the way counterclockwise (all the way clockwise was very blurry). .... to read and drive and has a real problem using my rangefinder.
Bushnell blurry display Rangefinders Questions & Answers (with ...
www.fixya.com > Forum > Tags > blurry display > Rangefinders display the display appears but does not display yardage Here is the link to the instruction manual if you need it; ... Sight target needs adjustment When i look ...
DIY Fix For A Malfunctioning Rangefinder On The Cheap
fardevice.com/diy-fix-for-a-malfunctioning-rangefinder/ 4 Common Malfunctioning Rangefinder Encountered (and How to Fix Them), or blank ... Bushnell Tour V3 Jolt Standard Edition Golf Laser Rangefinder .... This could be rooted to a blurry focus lens or laser output, so it's really important to ...
Bushnell - I am having difficulty seeing through my scope, all images ...
bushnell.com/global/customer.../i-am-having-difficulty-seeing-through-my-scope,-al I am having difficulty seeing through my scope, all images seem blurry. How can I properly focus ... What battery does my rangefinder take? All my pictures are ...
Bushnell Golf - Bushnell Golf
bushnellgolf.com/ The undisputed #1 Laser Rangefinder in golf ... Bushnell Tour Domination. The #1 Rangefinder in Professional Golf For Over A Decade. Learn More. The #1 ...
Bushnell Tour Z6 Laser Rangefinder - Review - MyGolfSpy.com
https://www.mygolfspy.com/bushnell-tour-z6-laser-rangefinder-review/ 6 posts - ‎4 authors
The Final Contender In The Rangefinder Round Up: The Bushnell Tour Z6 ... Our second entrant is the Callaway RAZR Rangefinder dropped a .... I have near perfect eyesight, but when target is clear, number is blurred and vice ...
Blurry vision Range finders - GPS/Range Finders/Mobile Apps - GolfWRX
www.golfwrx.com > ... > Equipment > GPS/Range Finders/Mobile Apps May 14, 2015 - 5 posts - ‎5 authors
What causes a range finder to have blurry vision through lens? Im looking to purchase a used Bushnell tour v2 in a couple minutes and I've ... Which Laser Rangefinder
2 Aug 2014
Pro 1M Slope = Bad, Bushnell = Good
1 Aug 2013
Problems with Bushnell Pinseeker 1500?
24 Jan 2009
More results from www.golfwrx.com
Jan 07, 2017 | Bushnell Optics
Not a clear picture
CRT projection televisions need periodic maintenance to maintain a clear picture. Typically, to maintain a sharp picture, they require cleaning and alignment every two or three years. If the television is being used in an environment where there is cigarette smoke or other smoke sources, the optics inside the television can become dirty and cause the picture to blur. Additionally, CRT focus and alignment wander over time, or physical CRT alignment can be knocked out if the set is bumped or dropped. All RCA CRT projection televisions have an "alignment" or "convergence" adjustment in their adjustment menus, which are fairly simple to use. The convergence feature is usually accessible from the main menu of the television. Check your User's Manual for the procedure to touch-up the convergence adjustment and see if you are able to achieve a sharper picture. If the optics in your set have not been cleaned for several years, or if it is in a smoky environment, the picture will be blurry and usually a brownish color, In any case, since the set is several years old at this point, it's likely due for a cleaning. This is best done by a technician, and mostly involves physical cleaning of internal lenses, the refractor mirror on the back of the chassis, and the back of the opaque display screen. An adjustment of CRT bias controls and individual CRT focus adjustments will bring further improvement in the image sharpness and clarity.
Jul 08, 2011 | RCA Televison & Video
My sister says I am blurry on her picture. I am using the logitech Webcam c500. In the small box on the right my picture is clear. What is the problem.
clean the lense with ear bud and Just try with adjusting the focus of camera just rotate the focus it will sharp the image. And adjust your room lights according to the brightness.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | Logitech Webcam
Does not focus after "far" objects when zoomed to 50mm or more ...
  1. If your images suddenly start looking blurry or distorted, try holding your camera up to the light. If your lens looks dirty, foggy or greasy, try applying lens solution with a lint-free cloth . Move the cloth in a circular motion until the lens dries. Do not apply lens-cleaning solution directly to the lens.
  2. If your images are still blurry, check your shooting mode. If you are shooting closeups, make sure you are using the "closeup" mode. Try to get within 2 feet of your subject before you shoot the picture. images can look more blurry when you are a long way from your subject
hope this helps you please do me rate on this issue
Dec 23, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
Problem with memory card
Make sure your camera is off.....Open flap to memory card.....On the side of your card you will see a little TAB that you can slide up and down....Your card is in the LOCKED POSITION which means you can't accidentally erase pictures stored on the card.....Simply slde the tab to the opposite position where it is now and you will have an unlocked card.....
Jan 06, 2009 | Konica Minolta DiMAGE Z6 Digital Camera
I was told last year when I researched it from the website, only a 2 GB card could be used.
Jul 22, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
DiMage Z6 turns off when trying to view pictures
I posted this on another section:
My Z6 worked flawlessly for over a year, then suddenly started shutting off for no reason. Tried new batteries, etc. The problem turned out to be the memory card. My advice, buy a GOOD card instead of a new camera! Keep in mind, flash cards DO have a "life" to them - meaning they can only be used / erased so many times before they will cause errors (so don't buy a used card off of ebay - no matter HOW good the deal seems). If your shutdown problem started with a "unable to read card" warning, then its the card. The camera is actually "protecting" itself by shutting down. Good luck!
Nov 25, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Blurry Pictures
Contact Customer Support this is possibly a CCD problem- they may still fix it.
May 29, 2007 | Konica Minolta DiMAGE Z6 Digital Camera
Viewfinder
There's a little scrolling wheel to the left of the viewfinder; move it up or down until the image is clearest.
Apr 07, 2007 | Canon PowerShot S3 IS Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
137 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
