Question about Brinkmann Grilling
I bought a used Cookin' Cajun Smoker and Grill manufactured by Bosman Industries, a division of Charmglow, and I would like a manual of suggested use.
SOURCE: how to use a smoker
How do you set up your smoker for fish ,I have a char broil electric .
Posted on May 05, 2008
  • 323 Answers
SOURCE: do not have the manual for my smoker
If it looks like the one in the picture you put the fire in the firebox (smaller one) on the left. Best to use lump charcoal and keep the temp low for smoking, around 210 to 245F. Open the lid on the smoke stack all the way until you gain some experience. If you keep too much smoke in too long it will be bitter. Place the meat on the far right side of the main barrel. Go to www.smokingmeat.com and join for free. There is a bunch of us there who share smoking recipies and methods of smoking, sauces, rubs, etc. Slow cooking and low temp are the secrets to smoking meat.
Posted on Jul 24, 2009
  • 60 Answers
SOURCE: how to make a smoker frpm a stndard grill
on a standard grill you build fire on one side of grill and put food on the other you can also put a pan ender food with water in it
Posted on Aug 16, 2009
  • 94 Answers
SOURCE: no user's manual for Smoke'n Grill Charcoal Smoker
Yes there is! Go to Brinkmans website and you should be able to get it there. If not, which would surprize me you can google smokers and you'll find more info than you care to see. Hope this helps.
Posted on Aug 23, 2009
Testimonial: "Thanks so very much! Had just a couple of problems getting to the Brinkmann's website, but once there it was very easy to find the manual."
  • 60 Answers
SOURCE: charmglow grill wont light with new burners
check the regulator and hose and if it is not that it is probably the washers under the valves take soapy water in a spray bottle spray and look for bubbles
Posted on Aug 30, 2009
I need part for Cajun Injector smoker
What's the model number and what's the part you need? If you're not sure what the part's called, check here:
https://www.manualslib.com/manual/733139/Cajun-Injector-Electric-Smoker.html?page=4
Feb 28, 2018 | Cajun Grilling
I have a double glass door cajun injector electric smoker. I need to replace the heating element located under wood chip pan.
online search using make and model or if have the owners manual call their customer service number
Nov 13, 2017 | Cajun Grilling
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
My smoker keeps causing my gfi to trip. What could be the problem?
You're the second person today to have this problem. If you're sure there's nothing wrong with your GFCI receptacle, there is a short in the wiring of the electrical side of the grill smoker.Most of it, you can visually inspect,. Look for damaged or frayed wires that may be touching the grill's steel frame. There my be a loose connection or an improperly wired connection. As I did with the other person ... I am including a link to the Owners Manual for your All-in-One Grill/Smoker. It has a good wiring schematic, that will help you trace the wiring and the connections.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ070_Manual.pdf
You can download and print the manual for future reference.
Good luck and I hope this helps you, to further troubleshoot and solve the problem. If it doesn't contact Traeger Industries Service Dept 7 days a week, 7am - 5pm @ 800-872-3437.
Apr 20, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Grill will not turn on
I assume you are referring to the auger motor. If so, have you checked the electric receptacle the g=auger motor is plugged into? Plug another electric appliance, like a lamp into the receptacle to see if the lamp works. If not, look for a tripped circuit breaker in your home's breaker panel. If one is tripped, make sure nothing is plugged into the offending receptacle and reset the breaker. Plug the auger motor back in to see if the breaker trips again. If does, there's an electrical issue with the auger motor or the cord.
If none of the above is the problem, i have included a link to Traeger Industries website. There you can find and download the Owners Manual for your Grill-Smoker, which also has a Trouble Shooting Section.
Feb 21, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Pellets keep feeding. cant control temp.
Are you trying to grill or smoke? In ether case, once the pellets ignite and the temperature you want has been reached, the switch should be turned to off. That should stop the auger pellet feed.
Also, are you using Traeger Pellets. They are the only one designed for this grill/smoker. If you're using heating pellets for a pellet stove, that also would cause that problem
If you've lost your Owners Manual, here's a link to it in a downloadable and printable pdf format.
Hope this helps. Please let me know.
Feb 06, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I need a replacement heating element for a Cajun injector electric smoker
Hi, replacing heating elements can be found at amazon, click here and take a look: Save Time Money and Energy with Induction Cooking. I hope this helped you. Have a nice day
Oct 21, 2010 | Bruce Foods Cajun Injector Creole Garlic...
Grilling Logo
648 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
