Question about Sunpentown SPT IM-100 Portable Ice Maker, for up to 2.5 lbs of Ice
I need a Liquid Filter ZB-1200 mine went out. I have had the machine 3 years. O is there a compatable one in service
All year long the machine will start at the 2. or 3. pull....Now i need Liquid Fire and it will only run for seconds.....Fuel line plugged...??If so how do i get it apart...?Thanks...Helmut.
fuel filter blocked
fuel pump failed
pressure regulator faulty
keep using liquid fire or other aerostart products and you run the very real possibility of damaging the engine
Fix the fault
Apr 29, 2016 | ATVs
I have a lamona washing machine that is only 1 year old and its started to stink. I have cleaned the machine with several hot washes, vinegar, washing machine cleaner ,the lot, and still it stinks after a...
it would be the air flow is blocked, washers get there air flow from the drain pipe, if this starts to get blocked it stops air flow but still allows water to go out, this will leave a lot of congestion on the washing machine door glass, use a descaler tablet on the hottest wash you can do and then leave the washer with it draw out, depending on the condition it can take upto 3 times with the descaler, use the liquid type and watch washer as you use it as you will need to put it in the draw every time it empties its cycle. overnight leave some bleach in the drum toilet type will do fine, this will not damage the washer but it will kill all the bad bacteria in the washer drum and the smell, then before use do a quick wash no heat wash or 30c. hope this helps.
Nov 08, 2017 | Washing Machines
I have a new Continental ice maker - bought 2 years ago, but was plugged in for first time yesterday. Motor won't run. Added water to proper level. Plugged in. Set cube size. In one minute red water...
Check the water pump, I had the same problem, the water pump was bad but unable to find replacement parts at this point. The pump is a ZB-1200 made by Zhongboa Motor Factory,
Good Luck
May 09, 2011 | Continental PortableCE-IM65151 Ice Maker...
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
When i have to change the air filter for my 05 bmw k1200s
every 10,000 miles or if it looks dirty "when its fully serviced!"
mine went on for years with its old filter still in it, coz there not cheep are they?
Mar 29, 2009 | 2005 BMW K 1200 S
Liquid leak while Vienna runs...but where from?
You may have a cracked coil inside the boiler and cracked nut of the coil going up to the wiring lug. Check it out, it will be a hair thin crack, almost invisible.
Feb 11, 2009 | Saeco Vienna De Luxe Espresso Machine
Thermal carafe has liquid in cavity and coffee does not stay hot
Call Cuisinart and see if they consider it an in-warranty issue (it has a 3-year warranty). If it were just the liquid issue that would be one thing, but since it's not keeping the coffee hot, then you have a hidden crack somewhere. Mine has the sloshy liquid issue, but I just live with it since it still keeps the heat inside. Otherwise, it's been a great coffeemaker that has lasted for over 6 years. As far as the coffee spilling everywhere - I would switch to paper filters (don't use the paper in conjunction with the gold tone filter). The filter basket door latch may be worn - as many problems as you're having, this may be a warranty issue that Cuisinart can solve.
Dec 18, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Allergic to detergent for front loaders
I have always used regular Tide powder in mine and my kids use Tide liquid in it. You just need to use about half as much. My man is a motor head so he gets DIRTY and I have three teens so I wash a lot of very dirty clothes. My clothes get very clean and I have never purchased the "special" Detergent.
I have had my Duet for three years.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cuisinart DCC-1200 Coffee on/off switch
To remove the faceplate:
You will need a tiny standardscrewdriver (I used one from an eyeglass repair kit) and a smallishphilips screwdriver. Begin by removing the carafe, the basket (andpermanent filter, if you have one), the water filter, and the inserton the underside of the flip-up lid. With the lid open, you willnotice two round screw covers towards the front of the coffeemaker toeither side of the filter basket. Remove these with the smallstandard screwdriver. This is impossible to do without damaging themsomewhat. Remove the two philips screws underneath .
There are nine clips that need to bereleased to remove the plastic top of your coffee maker. First, pressin on and release the two located on the back just below the lidhinge. With the small standard screwdriver, gently release the sixclips along the top edge of the casing. These are located two inback, near the corners and two along each side. You will have to getup underneath the plastic bezel, be gentle so that you do not bendthe stainless steel housing (if you do, gently bend it back intoplace before you put everything back together). Lay the coffeemakeron its back. The final clip is located in the carafe “nook” tothe back of the drip outlet. The upper plastic portion should nowlift straight up out of the coffeemaker.
With the coffeemaker upright, removethe four philips screws holding the faceplate in place. Remove thefaceplate by pulling it straight out towards you.
May 21, 2008 | Cuisinart DCC-1200 Coffee Maker
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Sunpentown SPT IM-100 Portable Ice Maker, for up to 2.5 lbs of Ice Logo
128 people viewed this question
Top Sunpentown Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Gregg Mahin
Gregg Mahin
Are you a Sunpentown Kitchen Appliances - Other Expert? Answer questions, earn points and help others
