Engine ran fine when parked, started the problem the following day when started, does not smoke and no prior notice of a problem
SOURCE: kohler k582 runs poorly at operating speed.
ALWAYS CHECK THE POINTS!!! 20 years operating this engine and you'd think I would know better. The points were severely pitted. Spec said .020 but actual is .013. The cold weather had me suspecting a carb problem. DOH!
SOURCE: Kohler CH20S losing power, blowing black smoke and oil
Sounds like engine is flodding. Have carb float checked, make sure it is at the correct height
SOURCE: Kohler 17.5 command. will not start
The woodruff / flywheel key is likely partially sheared. Pull off the air housing, remove the starting clutch, to get to where you can see the flywheel key. I bet you will find that the key has distorted. Easily replaced once flywheel is pulled. Make sure to use the correct key when replacing it.
SOURCE: i have a kohler cv14s engine is will not start it
readjust the valves to eliminate the backfire so it will start
SOURCE: kohler command 18 backfires when warmed up
kohler pro 18 on craftsman riding mower. Idles fine but lacks power at high speed. i installed a new carb. does not seem like it is not opening up full throttle and will back fire if i accelerate the throttle too fast.
