Question about Akai LCT2715 27 in. LCD Television
I have an 27
I have a 27'' LCD from Akai and will not turn on. It started with screen not showing blue but a garbulous of different colors. I shut it off then will turn back on in blue to normal. Now it will not show anything but a blinking yellow light on my ''Power'' indicator.
Is it worth fixing or just buy another LCD
  • 10,594 Answers
Akai is poor brand for after sale service and parts are really hard to get.
Luckily Shop Jimmy has main board, back light inverter board and power supply board in stock for Akai LCT2715 model
In your TV symptom of no-blue color shows problem with LCD controller board and current problem of blinking yellow light shows some thing wrong with back light inverter board.
Click Shop Jimmy to see circuit boards image and price info that will help you to decide repair it or not.
Thanks.
Posted on Jun 26, 2009
Akai lct2715 power supply repair needed. Please respond. Failure appears to have occured over several days. First picture had distortion at edges. Then blue AKAI screen would light but picture was not in...
I very highly doubt that is merely a power supply problem,I would suspect that it is a small signal board (aka scaler board) or at the very least,have the inverter boards checked
Jul 16, 2009 | Akai LCT2715 27 in. LCD Television
AKAI 27 Model #LCT2785TA
The message you are seeing means that the tv is not receiving a signal from the source. Try hooking up a different source such as a DVD player or a Cable Box to that same input on the tv. If you have picture and sound then the problem is with the original source. If that does not work then you have a bad Main bd.
Jul 10, 2009 | Televison & Video
Akai flat screen lcd tv.. turns itself off after about 10 min
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Jun 06, 2009 | Akai LCT2715 27 in. LCD Television
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Powering up and warmup problems
why does my lcd monitor change different colors no picture just turns to all sort of colors ViewSonic N2751W 27 in. LCD Television thanks 4 your help
Dec 05, 2007 | ViewSonic N2751W 27 in. LCD Television
Akai 3216 TV
I own a Akai TV but when we bought it, it was working fine. Then we moved it to a different position and plugged it in.. Now the red light keeps blinking and then it shuts off.. then about maybe a minute later it turned on by itself. can anyone tellme what the problem is???
Sep 18, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 27 in. LCD Television Logo
90 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
