Question about Acer Aspire 5100 Notebook
It just doesn't charge
I have an ACER aspire 5100 laptop and it just doesn't charge. It used to charge when I fiddled with the power connector for a bit, but my dad doesn't want to replace it, (Or maybe he will.)
Is there another way I can solve this, or am I pretty much screwed?
  • Broghan Jun 27, 2009
    Thanks, shredivya!
    That seemed to work perfectly.
    It's now charging =]
  • Broghan Jul 07, 2009
    It was the adaptor. I got an iGo universal adaptor and it works perfectly. =]
  • 71 Answers
1. Check the unit with the diff a/c adapter
2. You can check the adapter with the know good unit if you have one to isolate the issue.
3.If the adapter works fine with the diff unit you can check the battery , whether its healthy enough to take charge or not.
Based on this you can change the battery or adapater
Posted on Jun 26, 2009
  • Divya K
    Divya K Jun 29, 2009
    Hey thats sounds G8, can you also please let us know which is the step worked for you :)
White screen but plugin monitor works. is it the screen?
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5100/Aspire5100sp2.shtml
http://www.laptopscreen.com/English/model/Acer/ASPIRE~5100/
So you PHYSICALLY checked the connection of the Video Cable, TO the motherboard, TO the screen Inverter, and TO the back of the LCD screen?
Visual inspection will NOT do. If either motherboard connector, or LCD screen connector is loose, the width of this letter -> I < you won't see it, and it will affect the video signal.
The Video Cable connects to the motherboard under the Middle Cover, above the F4 and F5 key on the Keyboard. (Left edge of F4 key over to middle of F5 key)
[Middle Cover is Acer speak for Switch Cover. The cover strip above the Keyboard, and below the LCD screen ]
aspire-3100-5100-5600-lcd-cable-dc020007o00-.html
http://www.laptops-we-r.com/prestashop/aspire-5100-parts/109-acer-
Click on the view to enlarge. Top left side connects to the LCD screen. Rectangular Black connector with thick round cable, at the bottom, connects to the motherboard. Small cable coming off at the bottom, connects to the screen Inverter ]
From the motherboard connector the Video Cable routes up under the left Hinge, and into the Display Assembly. It then connects to the screen Inverter, and LCD screen.
From normal opening, and closing of the laptop, repeatedly, the Video Cable may become pinched.
This can lead to loose connections.
It can also lead to damage of the Video Cable.
If the sheath of the cable shows apparent signs of damage, the tiny wires inside may be damaged also.
Stretched/Broken
This means to ENSURE that the Video Cable is NOT the problem, a continuity test needs to be performed on all of the Video Cable's wires. (OHMS)
If an economical multimeter ($5 to $12) is not available, suggestion is to take it down to the nearest 'Mom and Pop' computer store, and have them check it. Labor charge should only be a few bucks.
Video Cable checks out it's on to the screen Inverter, for the diagnoses.
[NOTE*
This diagnoses is for an Acer Aspire 5100 Notebook PC. Uses a single (1) CCFL for a Backlight, and has a screen Inverter. Laptops that use LED's for a Backlight generally do not use a screen Inverter]
Did you test the screen Inverter, or replace it?
http://www.amazon.com/Acer-Aspire-5100-Inverter-PK070005U00/dp/B005F1N5O2
http://www.fonerbooks.com/test.htm
NOTE*
Takes a sensitive multimeter. Read fairly expensive.
Primer;
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
Click on the monitor. Suggest start out with your audio turned down ]
It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5100 Notebook PC uses a single (1) CCFL.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and Backlight.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Primer over.
If the screen Inverter is good, the LCD screen is bad.
Replace.
[The LCD screen, and the screen Inverter are a MATCHED unit.
When purchasing make sure you get the correct screen Inverter, or LCD screen ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 09, 2012 | Acer Aspire 5100 Notebook
How do I make the screen brighter on my Acer Aspire 5100 Laptop?
Try using keyboard combination Fn+right arrow. If this doesn't help right click on battery icon on taskbar, select Adjust screen brightness, then move slider for Screen Brightness to the right.
Sep 05, 2011 | Acer Aspire 5100 Notebook
Hi i have a acer aspire 5100-5674 laptop, i was using the computer when i saw the orange light meaning low battery, my computer was plugged in however... the next minute i know everything got turned off...
The first step is to check both the charger and the battery at a shop. If both are good then it could be a connector problem where the charger plugs in
Aug 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
My Acer Aspire 5100 just went blank. There is a
Generally, an indication that the battery is critically low. It appears that the AC adapter is not powering the system and not charging the battery.
Jan 09, 2010 | Acer Aspire 5100 Notebook
Acer aspire 1500 will not turn on
Try removing the battery and running the power directly through the power outlet. HP laptop dv6000 has the same problem.
Nov 06, 2009 | Acer Aspire 5100 Notebook
Power wont turn on acer aspire 5100
check 1st your charger if working.try other charger
Feb 21, 2009 | Acer Aspire 5100-3357 Notebook
Acer Aspire 5100 laptop drivers for xp
there should be all the drivers here, just choose the XP listing and then click the driver you want
Sep 01, 2008 | Acer Aspire 5100 Notebook
Power cuts off for acer aspire 5100
I,d suspect your problem will lie with, the systems CPU ( Processor ) or a component Overheating on the systems Motherboard. I would,nt suspect the Power Supply personally. unless your batterys not charging.
Mike @ compurepair.
Apr 22, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Red Battery Light
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Dec 10, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
