Question about HP Compaq dc7100 PC Desktop
My system will restart itself after shut down
I can shut the PC down and with in five minutes it will restart. What can i do to fix thix?
    An expert who has answered 500 questions.
  • 508 Answers
Re: My system will restart itself after shut down
You may have a virus, or malware, or RAM problems.
use a good malware or virus software, and run with the last updates. sometimes in SAVE MODE is better to run,
most of the time, could be your RAMS.
you can use carefully one dimm of ram first then another. to see if shutdown well or do the same.
Posted on Nov 06, 2007
0 characters
3 Points
My windows xp desktop keeps on shutting down after some minutes then the screen displays power safe mode. How do I get rid of this? TIA
If it gives you enought time, run cmd: and then execute
presuming c: is your system drive, else select
Also you might try Systerm Restore to point BERFORE this all happened.
If ask for restart, Restart
May 06, 2015 | PC Desktops
Acer Aspire 7560 wont restart
Before shutting down your system click on any programs still running and shut them down. This will cut the time for normal shut down to take place.
You could also run a hard drive diagnostic to see if it has any errors. There might be some if you don't let the computer shut down itself. Restarting can also cause the programs to become corrupt, if they didn't shut down right. Running a defrag on the drive will also help it shut down quicker.
Look on the net also for information on getting your PC to shut down quicker.
Oct 18, 2014 | Acer Aspire PC Desktops
HP Touchsmart IQ526- Black Screen and Amber LED please help! No display. Is this a hard drive issue?
Also had this issue on the Touchsmart IQ526. Removed the CMOS battery, waited some minutes, then powered on. The power button remained blue and had video again. Reinserted the CMOS battery and put the unit back together. Note - the battery was on the mainboard.
Mar 24, 2012 | HP TOUCHSMART IQ526 PC PC Desktop
My hp will come on stay on about 5 to 7 minutes then beep 2 times and shut off how do i fix this
Feb 15, 2012 | HP PC Desktops
I have an E machines t5026. I just upgraded the memory to 2GB 1x2 1gb sticks. The machine confirms the new memory is there and runs very quickly now. However it randomly shuts down and reboots by itself.....
Unexpected system shut down and restart after new hardware install is a result of installing the hardware either wrongly or its incompatible.
You will have to Reinstall the RAM chips.
Remove them, then fix them and make sure they are correctly fixed into *********** board.
If the RAM chips are compatible with you motherboard and it is correctly installed,
then the problem will be solved.
Thank you for using Fixya,
Aug 28, 2011 | E-Machines eMachines Desktop PC
Hi, my brother has a Compaq Presario 5000, and is having some trouble. The computer will boot to a point and then simply shut itself down. The point to which it gets before it shuts down is variable: it...
Once try to Re-Install your Operating System and Just after Installing your OS just once Mo niter your CPU usage in Task Manager if it is Simply raising to 80% to 100% then it is a issue of over heating
Aug 11, 2010 | Compaq Presario 5000 PC Desktop
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
Jan 19, 2010 | Dell Dimension 2400 PC Desktop
Just bought a new Windows Vista HP and when I type a letter on yahoo the ''letters are missing in every other words?''
try shutting it down and restarting the computer shut it down for about 5-10 minutes then restart it when u shut it off unplug the keyboard and just before you restart the computer plug in the keyboard
Sep 05, 2009 | HP PC Desktops
My pc turns off itself
Check your cpu heatsink/fan. This sounds like an overheating problem as the cpu has a sensor that will automatically shut down your system to prevent it from frying. Hope this helps.
May 12, 2009 | PC Desktops
HP Compaq dc7100 PC Desktop Logo
233 people viewed this question
Top HP PC Desktops Experts
Fred Sops
john smith
 Mike M
Mike M
Are you a HP PC Desktop Expert? Answer questions, earn points and help others
