Question about Toshiba 43A10 43" Rear Projection Television
Oil in rear projection t.v.
What kind of oil is inside the lenses? also will it make the picture quit if turned on when low on oil?
    Problem Solver:
  • 9 Answers
The "oil" is actually tube coolantthat is supposed to be between the lens and the tube. If the coolant was low you may have damaged the tube and maybe melted the lens if happened to be plastic.
Posted on Sep 21, 2009
What is the liquid inside the projector lenses?
Some lenses use an oil-like coolant or focusing aid.
Your lenses are called Intelifocus.
Hopes this helps some:)
Farmerbear
Aug 30, 2010 | RCA D61W20 61" Rear Projection Television
I want to know what kind of oil it is for inside the lenses
Thats optical coolant. You can get replacement coolant kits for phillips annd magnavox at www.tvrepairworld.com and the kit conains the coolant and the CD with instructions
Oct 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
I went to clean the lenses I took the top lens off then removed the plate under it. then I tried to remove the bottom lens and found out that there is oil uner it. WHAT KIND OF OIL IS IT? Where do I get it...
The coolant in the lens is conductive and will eat the boards. If you got any on one of the boards us alcohol to try and clean it off.
You may have caused your self a big problem.
Jun 26, 2009 | Toshiba 43A10 43" Rear Projection...
I have a RCA 60 inch TV and its about 12 or 13 years old. It has never been serviced or cleaned on the inside. The problem I'm having is the picture is starting to fade (quite a lot)and I was wondering if...
you probably have a little of both. the shutting off is definately heat related but could be too much dust on heatsinks, etc causing it to shutdown. cleaning may eliminate problem but could be a sign of an underlying issue..
the dust can really cause the picture to dim. most of these tvs you can pull the "lightbox" or guts out of the cabinet to clean all 3 lenses, and clean the mirror if needed. don't mess with the screens except cleaning the front from outside. usually a 1/4" driver will be all you need, and a soft cloth for the lenses. use compressed air or a vacuum to clean out dust which will help with cooling, but the picture is only effected by dust on lenses, mirror, and screens.
Feb 18, 2009 | RCA P56950 56" Rear Projection Television
Mitsubishi VS-1561
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Jan 05, 2009 | Mitsubishi WS48511 48" Rear Projection...
Foggy picture
That is your coolant projection fluid make sure you clean up any that may have went on chassis ect.....refill fluid in lense make sure it does not leak and try again, tube should be same as before, when chaning fluid in lenses always turn set on look into lenses if clear it is ok if dirty looking then change fluid.
Dec 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 55" rear projection screen
you need to take off your back cover take a can of air you can buy at electronics store and blow off the projector it probably has dust on it
Feb 07, 2008 | Philips Magnavox 9P6034C 60" Rear...
Inside the cabinet projected on the screen?
well . there are 4 things that can cause this..
1= the outer screens could be dirty.clean with screen protector cleaner.Spray on cloth and not on outer screens.
2= outside lenses of picture tubes could be dirty.Unit can be opened .Outside lenses can be cleaned with a lens cloth .Do not use paper towels or cotton as this my scratch surfaces of lenses.
3= inside of picture tubes could be dirty.This should be done by a repair shop only(dirty coolant inside tubes)
Dec 28, 2007 | Philips 55PP9401 55" Rear Projection...
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 43A10 43" Rear Projection Television Logo
490 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
