Question about Whirlpool Dryers
Timer will not rotate automatically, but still works manually.
  • 370 Answers
To fix this problem you must replace the timer.
Posted on Jun 26, 2009
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
I have an Intermatic E1020 timer and the manual control does not work consistently. The timer will turn the appliance on and off automatically but I cannot get the manual control to work. Please help!
If timer dial is rotating and keeping good time, then clock motor is good, and wiring is correct.
If timer turns the load on-off, then set of 156EB945A trippers are good.
http://waterheatertimer.org/pdf/Intermatic-e1020-english.pdf
I believe the manual control button reverses the program.
So if timer is ON, and manual is pushed, then timer turns OFF, and timer resumes programming at next tripper.
So the manual override is not an on-off switch.
All plug-in timers work same way, and most of the hardwire timers and in-wall timers.
The exception is the analog GE 15070, Woods 59017, Tork 701A, Intermatic E1120, Intermatic KM2 series. These timers have a true on-and-off switch that slides back and forth.
http://waterheatertimer.org/Programmable.html#15070
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | Hardware & Accessories
Automatic sprinklers (Intermatic timer) do not work in automatic, but manual does work. When I cycle the timer, the solenoid activates but not enough for the sprinklers to spray. Manual works fine. Any...
If manual override works, and dial rotates on time each 24-hours, then worn trippers are suspect.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Upvote the help.
May 28, 2011 | Intermatic R8806P101C -...
How do I work this timer? Model 59200. Does it work on any kind of lamp? Do I turn the lamp on? Tried it and didn't work, never turned the lamp off. Manual sheet not much help. Thanks for more info. Rita
Open following link to identify timer and see manual plus written programming steps:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Lamp must be turned ON, and Bulb is good.
Raise and lower a few segments on the timer.
Plug timer into wall, and plug lamp into timer.
Manually rotate timer dial clockwise to watch lamp turn on-off.
Notice also that timer has switch located on top.
Move switch into one position and manually rotate dial again.
Move switch to other position and manually rotate dial again.
This will tell you how to set timer switch and segments.
To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and segments click a switch back and forth that turns circuit on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 07, 2011 | Woods 59200 Lamp and Appliance Timer with...
How do you program the 15119 timer? I have the tabs "up" for the times that I want the timer off and it is not working. The switch is set to "timer on". It does work when in the...
I was looking at GE timers at Home Depot tonight.
Timer ON is correct setting.
Segments up should be lights off.
You lights turn ON with outlet on, so lamp, bulb and electricity are good.
Troubleshoot your timer:
What happens when you manually rotate the dial clockwise?
Do lights turn on and off at scheduled times?
Move override switch both directions and rotate dial manually with switch in each position.
Are the segments pulled all the way up?
If lights do not respond when dial is rotated manually, and segments are all the way up, then timer is broken.
If lights turn on-off with manual rotation, then check if clock motor is rotating dial.
If dial is not rotating, then timer is broken.
The way these timers work is this:
Timer clock with plastic gears rotates dial.
Dial rotates as time passes.
Plastic arm rides along outside edge of segments. See photo below.
When segment is pulled up, plastic arm clicks inward via spring action.
The moving arm opens electrical contacts that turn lights OFF.
If dial is not rotating, or the spring is worn out, or the plastic arm broken off, or the contacts fused together, or override wire is disconnected, then timer is broken.
I test these timers.
4-6% arrive defective, and most last 1 or 2 seasons and then they break.
But they are priced low and easily replaced.
geno_3245_190.jpg Plastic arm rides along segments
geno_3245_191.jpg Segments pulled up on GE 15207
Dec 16, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
Lights won't automatically turn on BUT will automatically go off
Are you using the red peg for 'on' and black for 'off'?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 17, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
