Question about Boating
Not getting any spark to the plugs
How do I check the stator to see if its working?This problem is for a 750 ST Kawasaki Jet Ski, 1994
  • thomas foster
    thomas foster May 11, 2010
    you have to run a resistance test on it but what is the problem? no fire?
    Champion:
  • 207 Answers
For no spark the cdi is a better bet and there is no test for it but process of elimination buy cheapest part first you can use a test light to see if your getting power from your startor to the cdi and coils if the cdi has power when you turn it over its 90% its the cdi
Posted on Jun 27, 2009
Js 440 jet ski has no spark
check plugs are good , is there a spark at both plugs and make sure both are to earth as they spark at the same time known as a waisted spark coil ? remove plugs from caps and put a metal rod of some sort in them and hold against your hand and crank engine and you will feel a slight voltage if working ! wont hurt you !! if no remove caps and repete ! if no check kill switch isnt stuck or corroded etc ! P...
Dec 02, 2013 | Encore Software Kawasaki Jet Ski...
Kawasaki watercraft
compression check , 100psi or more ! battery and connections good ?
Jul 06, 2013 | WSM 1995-1997 Kawasaki Sxi 750 Cc Jet Ski...
Need a service manual for 1995 Kawasaki ST jet ski
You might want to post this question in a different section. This is the computer games section.
Aug 13, 2012 | Video Game Consoles & Games
My 1994 kawasaki 750ss jet ski has very low compression in one cylinder how do I repair?
Since this is not a computer game, you might want to repost in the correct catagory.
Jun 01, 2012 | Video Game Consoles & Games
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
I have a 1994 Polaris jet ski slt 750 that will start up when it's out of the water but when I put it in the water it won't start. It just started doing this. I had the battery checked and was told it was...
You are deal with moisture corrosion in your carburetor. Take the carb off and clean it paying attention to the corrosion on the rubber tipped needle. Also open your electronics box and make sure that it is dry.
Aug 08, 2010 | Encore Software Kawasaki Jet Ski...
I have a 1989 kawasaki js 550 jet ski. The engine turns over but I do not get spark out of either spark plug? what is the issue and how do I trace the electrical problem?
Check the ignition coils to begin with and basically follow the wiring back to the stator making sure you have proper voltage at each component, also check to make sure everything is grounded properly, it is very common for the grounds to be corroded on marine equipment. I will have to check but I am sure I have a dealer service/ troubleshooting manual for kawasaki skis, so if you have any other questions about yours let me know.
Nov 19, 2009 | 1989 kawasaki GTR 1000
Removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Jun 15, 2009 | Boating
Boating Logo
366 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
