Question about Sony KP-57WS500 57" Rear Projection Television
My tv recently started to show red lines, most visible when the scene is dark. They are curved, in different directions top and bottom. They are spaced several inches apart.
You may have a few dead pixels, or maybe it's leaking. I suggest you replace it.
Posted on Jun 26, 2009
Big red circle in the middle of the picture
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 30, 2010 | Hitachi 51F59 51" HDTV Projection...
Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Dec 20, 2009 | Toshiba 50HP66 50 in. Plasma Television
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
Red and green curved lines when the screen is dark
Your convergence board is going out. this will have to be replaced. i would take a look at the main logic board as well. it could have minor point breakage.
Feb 09, 2009 | Sony KP-57HW40 57" Rear Projection...
Curved faint white lines like a rainbow
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved,
just with that one solution
Give it a try, it's free and simple :D
Had a similar problem , mine was like yours but with
different colors....fallowed the directions in that
blog....and it was fixed in 10 min :D
The Guy Ken, who posted it is a GOD !!!!!
Hope the blog helps you and anyone with this or similar
problems !
Jean
Feb 01, 2009 | Sony KP-57WV600 57" Rear Projection...
Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Jul 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Dark vertical lines on tv screen
looks like lcd panel is off.the cost is abit less of anew tv!
Jul 07, 2008 | Televison & Video
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Sony KP-57WS500 57" Rear Projection Television Logo
172 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
