Question about Nvidia GeForce FX 5200 Video Card Graphic
Display won;t turn on from a reboot
I'm running the supplied Nvidia GEforce 5200 graphics card on a Dell Dimension 8200. I attempted to correct a problem in which the display turned itself off randomly for 1 -5 seconds. So I downloaded the latest driver from the Nvidia site for this graphics card. Now the display works correctly only if I start the computer from a cold start. If I just reboot the computer I get a "no signal" on my flat panel display and I'm running blind. Any ideas?
  • ken seal Nov 08, 2007
    i have a ATI 9800se graphics card that i removed from a Tiny Demon 3200 pc and put in my sons pc for a while so as he could play a new game he had purchased as the graphics werenot very good from his card.I have now bought a new ATI 9800se card to put back in the Tiny Demon,having installed it i get no display NO SIGNAL INPUT is displayed for a couple of seconds and then the screen is black.I removed the card and tryed it in my sons pc works fine.I even put the original 9800se card back into the tiny and it does exactly the same yet this card worked fine before i removed it.I have since put a NAVIDIA card in the TINY and this woks fine, Any suggestions?
    Champion:
  • 209 Answers
To: Svodon,
it shows that you the video card you installed having loose contact try to dismantle then clean with pencil eraser the contact points(bronze color) on both sides wipe with clean cloth make sure no residues of eraser before you install to prevent mis contact. after cleaning make sure you will install firmly. ihope this will help your problem and hoping your positive response
Posted on Dec 03, 2007
I have a Dell Vostro 400 and two video cards. Only one card will work and it is an Nvidia GeForce FX 5200.The other one is an ATI Radeon HD 2400 PRO. These are the specs from the two graphics cards:...
you cant join two different platform vga cards. simply because they have their own platform and have separate drivers, so they conflict each other thus causing one of them shut off or disable..
Jun 01, 2010 | XFX NVIDIA GeForce FX5200 Graphic Card
After installing the graphics card (nvidia geforce fx 5200 pci) it boots up fine then when i try to play a game it will come on then on starting the game it will just reboot please help
Make sure the graphics card can handle the games minimum requirements. if the game is trying to push more than the card can handle it will either kick you back to the desktop or reboot the computer.
Mar 17, 2010 | Nvidia GeForce FX 5200 Video Card Graphic
Having problems installing a Geforce fx5500 on my dell deminsion
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped  install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Feb 07, 2010 | XFX GeForce FX 5500 Graphic Card
Need graphic card upgrade for Dell Dimension 4500 w/ pixel shader
This is an older machine that has a 4x AGP port for graphics cards. The good news is that cards for this slot are cheap...usually in the 30-50 dollar range. The downside is that you wont get the greatest performance out of them. I would recommend going with a Geforce FX 5200.
Nov 24, 2009 | Dell Dimension 4500 PC Desktop
Monitor going to power save mode and freezing
Hi, i have had that problem before and its wasn't the graphics card drivers, it was loose, anyway for you case go to device manager and uninstall the graphics drivers from there then restart and install then manual by updating and locate the exact location from the cd or any other location that has them.
That should help
Cheers
Apr 27, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
Nvidia GeForce FX 5200 Video Card Graphic Logo
108 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
