Question about Goodman Heating & Cooling
Model GSC130481AG, S# 0808548576 The common wire to the compressor rubbed through the wire insulation and melted a hole in the discharge line from the compressor. Upon loosing all of the refrigerant the compressor ran hot a warped the valves. I repaired the leak and replace the compressor and liquid line filter drier. Upon start up the system would take little refrigerant. The suction pressure went into a vacuum with a 115# head pressure. What is wrong here?
  • serviceman75 Jun 26, 2009
    This was not a burn out. The compressor ran too hot and warped the valves. I have blown out the evaporator, orifice and lines from the condensing unit to the air handler. Could there be a restriction in the condenser coil? Could something have broken loose from the old compressor? Would this be the manufacture's responsibility?
    Yes. Everything has been done text book perfectly. Very thorough. The ONLY thing that I have not done is to isolate the condensing unit and blow through it with nitrogen. The problem here is that i can't blow through the condenser coil effectively with the compressor in the circuit.
  • 3,361 Answers
You have a restriction in the system. Probably in the TXV or orifice in the A/H.
The burn out sent trash/fragments through the system. I would open the sytem and blow nitrogen through, then pull a deep vacuum.
You may need to install a low side filter/drier. When you open the system change out the high side drier again for sure.
Posted on Jun 26, 2009
  • steve
    steve Jun 26, 2009
    Did you vacuum the system to 500 microns after the repairs were done?
Frost forms on the coolant line from compressor to evap coil. At small foam insulation piece it has a chance to melt then drips on floor
Not good... no way.
That is an old time symptom of an inadequate refrigerant charge. The foam insulation rapidly loses any effectiveness when saturated.
Fact is... refrigerant lines leaving the compressor ought to be too warm to be attracting condensation...
Frost is highly problematic (as is water dripping anywhere inside the house).
Hope that helps!
May 31, 2015 | Frost Refrigerators
How to discharge compressor capacitor
put a insulated screwdriver across the terminals always unplug before working on unit
Mar 08, 2014 | U-Line Icemaker
How to find the hot (Black) wire on power a new samsung fridge power cord since both are black?
First, get a $10 voltage tester. Since both wires are black, it may not matter which way you hook it up--if that is your problem. still, you can find the hot,and common like this:
You'll need a patent ground. If the unit is grounded, just touch one probe to the metal.
with the compressor running, carefully work the sharp tip through the insulation of one wire ( makes a very small hole in the insulation that poses no hazard). If the voltage is consistent with your other hot readings, then that's your hot (110/120). if it reads lower when the compressor is working, then that's your common (white). You should get the greatest difference (voltage drop in common line) right when the unit starts.
or, just call Samsung.
Oct 23, 2013 | Samsung RS2630WW Side by Side Refrigerator
Seat
You can't. A harness will melt if it gets enough heat. All you can do is make sure the airflow around the battery is good. This will also help the battery when it is charging. To protect the harness from meltdown through rubbing you can fit heatshrink tubing or Aramid/kevlar tubing to prevent the rubbing from damaging the insulation.
May 05, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
15amp fuse blows on honda shadow vt600
Blown fused happen because of wires rubbing the insulation off and grounding out on the frame usually. A positive and negative could be touching on lights, switches, or relays. It could be a broken positive wire that is almost disconnected. You can trace the wires and see if you can find hot spots that have melted the insulation.
May 06, 2012 | 2002 Honda VT 600 C Shadow
96 dodge intrepid brake lamps do not turn off. already replaced brake lamp switch. lights stay on even after removing fuse. please help
Hmmm... sounds like a power( live line ) melted the insulation and fused together w/ the brake line, thus it powers up your brake light.
Check your rear brake wire harness leading to the front connection main harness., if the harness are covered w/ plastic insulation, cut the insulation and look for a wire that melted and fused together.
If you found the wire, seperate it and put some insulator tape to prevent power line shorting.
The power line usually colored RED.
Hope that helps!
Nov 06, 2011 | 1996 Dodge Intrepid
Wires melting together were they hook to the bulkhead fitting going to my compressor
it sounds like the wires came in contact with each other probably the wire insulation wore off with vibration. the wires are forming an arc similar to welding until the arc is terminated by the circuit breaker when it trips. wires need to be replaced make sure all connections starting from the circuit breaker all the way to the compressor are tight you don,t want wires melting and causing a fire it can damage your equipment, your property to say the least..
Best of luck.
May 31, 2011 | Weather King 10AJA6001AH Air Conditioner
Burnt wiring insulation dishwasher & aluminum house wire
your problem is most likely the aluminum wiring. Begin by running a copper line to your dishwasher eliminating the aluminum. use Romex Building Wire, NM-B 12/2 with ground and a 20 Amp circuit breaker
Oct 25, 2009 | Dishwashers
Where is the fuse for a 1981 cadillac coupe deville airconditioner
It will be a fusable link which is in the wiring a few inches away fro the connector to the ac compressor. In is a peice of very thin wiring spliced in the harness that will melt down inside the insulation. Wiggle the insulation untill you find the break in that wire
Sep 24, 2009 | 1980 Cadillac Deville
Need wiring diagram
check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
May 09, 2009 | Heating & Cooling
Heating & Cooling Logo
582 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
