Question about Electrolux Centralux Vacuum
Filtex central vacuum
Not much suction--think i need an new motor
  • 50 Answers
Check suction at main unit. If it is not good and the unit is empty you might need a new motor. If good there and one of the inlets is open, connect and disconnect the main line at the main unit. If it labors each time the line is connected, there is an obstruction in the line. If it doesn't labor you have a leak in your line.
Give me feed back.
Posted on Jun 27, 2009
My dryson dc40 beater bar will not spin and there is no suction
The brush bar motor or one of the switches may be defective. If the brush is not spinning it will not pick up anything from carpet leading many to think it has no suction. Feel for suction down by the brush bar. If you have no suction it may have a clog or need new filters. Make sure the changeover valve that switches suction from floor to tools is working properly.
Mar 25, 2018 | Dyson Vacuums
We have an Electrolux 6500 SR Model C102G. We
yes it wears out it is a common problem i eliminated several of them for people its a job that takes alot of patience i opt to just eliminate the part its sort of useless and causes your machine to act contrary if you want to replace the part here is the place Electrolux Aerus 4526 Maccorkle Avenue
South Charleston, WV 25309-1409
(304) 768-2158.. if you cant fix it contact me and i will repair it for $35.00 plus parts or no parts either way it can be fixed the above contact is the dealer i use for parts
Jun 13, 2010 | Electrolux Epic 6500 Vacuum
My miele titan is not turning on when plugged in. i think it might be some sort of clog? but the electric head is working... help!
Wow!, that's not typical of a Miele, especially a new model like the Titan which has been on the market for less than 2 years. If I read this correctly, your power nozzle (electric head) is working, but the main suction motor is not. Thta's usually a sign that the carbon brushes in your suction motor are stuck or too short. Again, not a common problem with Miele. A clog could cause your machine to run hot from reduced airflow and then shut down until it cools, but it would shut the whole machine down, not just the suction motor.
Is your power dial, (located just forward of the main switch and cord retractor buttons) set to minimum? If so, you just might not be getting enough suction. If, after turning the dial to maximum, you still get no suction, then you should definitely take it back to the dealer you bought it from. You have a 7 year motor warranty and a 1 year warranty on all non-wearing components. If you bought your vacuum on the internet then you can go to www.mieleusa.com and search for a local dealer. There is a 'Dealer Locator' link on the left side menu.
May 18, 2010 | Vacuums
Lack of suction
Do not think its motor .......Yoy need to see thats its not Cloged if so clean.......
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Motor makes loud growling noise, no suction on model 270 i Miele canister style vacuum
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately that normally means the motor has shot its bearings and/or its carbon brushes. I think it is time to purchase a new one. On the bright side there are some rreally great vacuums out there! If you want any help choosing a new machine send me a message. Happy Vacuuming :)
Sep 04, 2009 | Vacuums
Powerforce bagless turbo roars and has poor suction
You would think they would come with some kind of Warranty!!!! ~ Most of the Time the Motors are Fine, And they just need new bearings!, As its easier to replace the Whole motor unit then Fix whats broke!
Jul 07, 2009 | Bissell 6594 PowerForce Bagless Upright...
Dyson vacum cleaner lost suction got the DC14 and it doesn't seem to have much suction in the floor head, the hose still has good suction. I have checked all the paths for blockage and there is none.
Forgive me if I'm thinking of the wrong model, but I think the DC14 has a short length of clear plastic tubing between the floor head and the fixed vacuum pipe-work. This tube can split and let air in which, of course, reduces suction at the head. You need to inspect it very carefully, as the split is often where it's really difficult to see!
If this is the problem, a repair with tape is possible but rarely completely satisfactory. A new bit of tube is the best solution.
Apr 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
NO SUCTION
If you have no suction, there are only a couple of things that could cause it. As you have checked for blockage, and changed your filters, you may have a vacuum motor with bad bearings, or broken fan blades (inside/on the vacuum motor). Either symptom points towards a vacuum motor being bad and needing replaced.
Jan 21, 2009 | Electrolux Central Vacuum
Motor works, but no suction! what do you think?
No suction usually means a clog somewhere or bad filters. The hose and/or the dirt inlet by the brush roll may be coulded. The belt may have stretched enough to not turn the brush roll under load and that can seem like no suction. The worst is the motor is running at full speed, which would mean replacing the motor.
Apr 24, 2008 | Vacuums
Low suction
Replacing the motor cover solved the problem, it must have been warped and was letting suction out thru it.
Jan 03, 2008 | Vacuums
Electrolux Centralux Vacuum Logo
206 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
